Bit of a copy paste job from the OS88 vs Holinger thread but I'll plonk it here also...
For those interested in an OS88, here is the oiling issue that needs to be rectified before you put it in the car.
The little slot where the light is coming through is the breather for the box. There is no cover for it and the gear acts like a paddle wheel and pumps oil up the hole and through the hose. So a cover will be made to stop this.
The oil breather fitting also needs to be drilled and tapped. My fitting popped out once it got in the car. OS must use clag glue to secure the fitting... it doesn't last.
I am also changing the sensor that lives in the bell housing.
i should have the box back by the end of the week ?
  • Like 3
  • 3 weeks later...
Finally, something worth updating about!
Gearbox is back in!
Fabrication of PS res is mostly done. The 2 x 4 port MAC valves are mounted.
Airbox, gate lines will hopefully be tomorrow.
Transfer case to front diff shaft uni joints are rooooooooooted. Thats away getting sorted ATM.
2D8250FD-115F-43B8-948B-DB4BE040E3BC_zps
E6CA88E0-FA61-4B0D-B57C-88B6B97EB7B0_zps
  • Like 2
24 minutes ago, iruvyouskyrine said:
Why 2x 4 port valves? Twin gates I guess?
A 4 port gives better control over a wider spread of pressure. You can get away with less spring in the gate incase you want to turn it down (wet track day etc). Scott wanted 2 valves and considering I didn't have a setup yet, that's what went on. One valve per gate.
Going off "Intune's" car, a combo of 1 bar springs gave a gate pressure of 19 psi or so (going off the tial spring sheet). I've put 0.9 bar springs in. See how we go.
  • Like 2
Airbox almost completed. A much larger filter is going in. A K&N RF-1041 which measures 6 inch flange, 7.5 inch base, 5 inch top and 7.5 inches long. Going through the airbox is a spun up 6 inch to 4 inch funnel. The factory airbox snorkel will be also used then off to get coated black!
With any luck, gate lines tomorrow.
  • Like 2
It is what it is, Pete.
Not using rubber around there, that's bloody lunacy! I'd much prefer not have a rubber line fail and a gate not open when hard up it. Braided -3 lines with heat shield.
    • Hi, wondering if the HKS bar and water reservoir still available? Thanks
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
