For anyone else playing along re timing issue.
A good unbiased thread here.
Unsurprisingly issues occurs on a number of ECUs, not limited to Haltech, and even features our OP(and others) claiming the same issue on a PowerFC, madness...
Seems like most ECU manufacturers and Tuners were aware of and had produces solutions to address it, including modified/better CAS discs, crank triggers, etc.
Too much was said for me to not look into it as a precaution - So thanks for that even if your caps are flat.
I am probably as far from a flat clapper as you can get!
Yes it is an issue with not just Haltech, motec m800 and earlier, link etc all suffer from it.
With a good CAS and good signal wires PFC, Nistune and Adaptronic won't suffer from it, if you get really bored you can listen to a youtube video or post Andy from Adaptronic made about it too. So for a plug in ECU designed for that engine I think it's a rubbish ECU choice if you need to fit aftermarket sensors.
It's always to learn something new :D
Haltech "claim" not an issue with Platinum Pro, but was a problem on earlier ECUs, guess I'll find out it ever happens.
So I guess the bombshell here is old shit can be problematic... but new shit has less issues.. Who knew!
LOL it's defiantly a problem with the Platinum pro, even worse with the Elite range but I won't tag Jono Pace in this thread for him to rage about them.
Don't always believe the marking bullshit that comes from a manufacturer, i am sure you tuner would have tuned you car extremely safe up top if it was showing any issues.
Just now, ActionDan said:
He might have given me an ear bashing on FB about it already?
Wonder why my car hasn't seen it. Maybe the key is don't drive it.
it may well have it, you can tune around it to a degree or just ignore it like most do.
That must be it then, I can't there being any possibility that it's just working properly.
I'll be ready to replace the ECU when I put my TH400 in.
Just put a crank trigger kit on it!
You will need it for the 1000hp and your TH400
  • Like 1
Setup a real crank trigger.
Throw OEM CAS disc in the bin. Fit an aftermarket disc.
Run whatever ECU you want or as many Haltech products as your passenger footwell can fit. Job done.
  • Like 2
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
