It's even worse at the moment as the closer can is not vented atmo over near the turbo too, that will be changed ;)
The back one is not so bad, if it weeps a little it sits up on that little lip.
Ideally I need a redesigned can up behind the shock tower incorporating all fittings with a big ass breather on top.
But that's $$
I've had it blast out oil all over that side of the engine and other than the smell, no issues.
When you don't make power, you don;t have heat issues.
Oh and I did put the stock heat shield back.
39 minutes ago, ActionDan said:
So... we need to see some videos of the guages at work...
You have them.
Boost gauge isn't connected at the moment. Considering deleting that too. Ah, I have the Nismo one in the centre but that reads to 1.4 bar only.
6 minutes ago, ActionDan said:
They were shit clips and you know it.
Get some in the daylight with a decent camera and a proper mount
That's fine, but I haven't driven or seen the car since.
I have to put the bloody thing back together and get the wheels pointing the right way before that shit.
Ill put it on the list of things to do.
On 05/10/2017 at 11:32 AM, ActionDan said:
That was my most recent test and finally I have zero oil control issues :D
Because you confused the feck out of the oil and it has no clue where the feck it should go...so just sits in the engine feeling dejected
Looks worse than it is.
Rockers Tee'd into can and vented atmo.
Dipstick and "balance pipe" Tee'd into another can and vented.
Balance pipe is Nissan's attempt to equalise sump and head pressure. Connects sump to rear of intake rocker.
From factory, in 1989....
  • 3 weeks later...
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
