5 hours ago, ActionDan said:
I've seen plenty of videos, results look pretty bloody good to me!
Maybe he just got sick of some of the carry on that goes on in build threads?
Given how some people behave around here these days, there's much less of an incentive to share all the ups and downs of a build.
 I got jumped on from the getgo because I wanted response , said cannot be done ,  go buy a V8 . I got a pretty good result and not a word from the stirrers , LOL
Pauls car is great , plenty of power with good response , win win
PPG honestly is good enough to daily, it's easy to use doesn't crunch when you use clutch and is relatively quiet.
When mine went in I drove it to and from work in peak hour for a week and didn't get frustrated at all, my rear diff is generally louder
On 8/6/2018 at 10:28 AM, Piggaz said:
In the garage on the trickle charger. ?
Drive it every couple of weeks and just getting used to the box. Low speed, low rpm shifting without the clutch without making it go BANG/CRASH. Getting there ?.
Wont be touching it again for a very long time. The level of “over it” is very high.
With the 1.45 housing it went 517 AWKW, up from 486. Turbine speed remained the same at 122,000 RPM.
That is a healthy gain, was there much difference in response
2-300 RPM I reckon. Totally unsure which one I like to be honest. The 1.05 was “so right”. More Kms needed.
  • Haha 1
2-300 rpm seems like a reasonable enough trade off for an extra 30kw
I guess it comes down to what the car gets used for though
  • 10 months later...
Update.
Bought some new wheels...CE28N SL’s in 18x 10.5+22 wearing 295/30x18 AD08R’s. Might put them on in the next 3 months then push it back in the garage and whack it back on the trickle charger. ?
  • Like 4
7 hours ago, ActionDan said:
No roll racing videos, power cruise, drags, circuit, traffic light racing, hard parking, nothing...
This thread does not deliver.
You need to Youtoob better
The truth is out there.
Well, a hill climb somewhere is anyway
But, in saying that, all the good uns should get out and give me pleasure to my eyes and ears.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
