yeah, just gonna give it a mad degrease and scuff back and hit it with some of the new mix and some 15min clear.
planning on doing that saturday morning, motor in saturday night.
should be fully off da chain
need to know the factory paint code for the airbox..
gonna paint strip it and repaint it
future ref: Nissan Navara D21 Mechanical speedo sender Part No. 32702-02G17
japan auto 1 on railway road epping.
spoke to the ever so fabulous kenan from edge motorworks.
they will give it a go over and start it for me. not long to go
  • Like 1
you see any micras in the wreckers moh? :woot:
Took us two hours to get that flamin mongrel out with the box
:O
When my mate and I took a crack, it took us forever to take it out.
went to work on saturday, ended up in geelong at the shannons classic show
then came home to find this in my drive way
1477804_10202624183548735_1777608622_n.j
quickly got to work!
1455201_10202625435260027_106380254_n.jp
1471783_10202625435540034_1260255376_n.j
my right hand man Youssef helping out as always!
and monday was a good day!
1455155_10202636864465750_578359387_n.jp
thats all for tonight.
currently stripping the RB20 of all the bolt ons for cleaning and fitting to the RB26, just need to bolt up the extra lines. finish the plumbing, do the shaft and were ready to f**king go!
1460244_10202638295981537_273636787_n.jp
also heard you can use the rb20 mounts for the rb26, mine are fouling on the oil pressure switch. do i need to trim it or am i doing it wrong?
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
