Are you a PC or MAC User?
81 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 349
Posted Images
PC, because I can get the same hardware spec if I build it myself for much less $$$ compared to Mac.
Plus now days Mac use hardware from intel & the lot so you are basically paying $$$ for OSX & that all in one PC mointor box thing.
Mac because they have the best displays that I have seen.
Gee, you like Dell that much? Cause that's what Apple use in their iMacs. Yes, Dell screens. You can buy one too for a PC for about $900 (or a Samsung equiv for $700) and even with that spend you can build a PC which will beat the shit out of an equivalent priced Mac.
Yes, I'm PC. OSX is f**king gh4y and Apple can eat a dick. And yes, I've spent more than enough time fvcking around with that homo OS to know.
And "Apple people" are total fvckwits. Who in their right mind would queue for five hours, let alone fly halfway round the world to buy a phone? Seriously.
Whoa ease up there cowboy… Did I say anything about owning an imac?
I have a mbp and its has the best display of any laptop I have ever used so that's one of the reasons why I bought it. The fact that it never crashes/freezes/windows has encountered an error on me is kinda cool too since every pc I have owned has done.
Your question do I like Dell that much? How much exactly are we talkin, cause I never even said I liked anything any amount. Talk about a loaded question.
I agree waiting in line for however long to get a phone or whatever is pretty retarted, but you know what's even more retarted….Getting mad about what other people do in order to get what makes them happy. Do you realise how dumb that comes across?
All these people with the fanboy shit is so lame, they are more obsessed with hating on someone then the person is about their shit. Pathetic really.
It's all good mate, just taking the piss.
I do hate Apple with a passion though.
And my windows never crashes, freezes or anything either. If it does then you're doin' it wrong!
Apple can still eat a dick :P
    • f**king around with the bro
    • Ludenham   44.2 tops day no issues
    • Then today, I went to visit a man with an r33 hat Peter and Road and Race sorted the alignment. As it is being set up for general track/hillclimbs etc it has a heap of caster (7o), less camber than I am used to (1o front and 2o rear, as the caster looks after that in turns without the braking downsides), 3mm front toe out and 0 toe rear. Will see how that goes and track tyre wear to see if it does need more camber, but adjsustment is also limited with nismo arms and adjustable bushes at only 1 end. It does have a bent inner tie rod on the driver's side front but as it came up within spec I'll just leave that as is. So, that is getting close to my chapter of this story....could of tidy ups then a shakedown in early October before it finds a new home.
    • So, it went to Unigroup for a run in and tune on Friday, everything went (generally) well. In terms of fixes, the engine was good and there were no leaks. It needed plugs (I hadn't checked them because the coil pack cover was on a new engine and I couldn't imagine they weren't new.....but turns out the temporary plugs to just keep it sealed up were in there.....new plugs gapped to 0.8 and it was fine from there. Also, there was a little preload on the clutch slave which caused some slip. I haven't had the box off so I don't know what the clutch looks like; my guess it is brand new and the pedal had not been adjusted....backed that off a bit and it held fine. Last thing will have Dose crying....the idle especially when cold is a bit difficult between the cams, forward plenum, atmo blow off valve and an 80s air management system. It is fine when hot but a little uneven when cold, will see if I can sort or at least improve that one cold morning. Other than that, tuning went fine. It made 245 but was pulled back to 227 which 2 opportunities to improve in future. 1. The factory CAS is not great and was jumping around at high RPM, so Mark took 2 degrees out up top (that is why it stops making power and lost 20kw). Very safe this way and the extra power is available but will require a more modern ECU and better cam (or even better crank) sensor 2. The 2871 in factory housings is very big for a low mount, and the internal wastegate is too small, so it was creeping from mid range all the way to redline....the duty cycle on the boost controller is turned down a little for safety. That is much harder to fix, it would need a large external gate and that would require a whole bunch of other changes, so it will go as it is for now. It feels nice and healthy and safe, so should be good for about a billion laps like this.
    • what sort of caliper are they? If they are a slider and you gave everything a good clean, you might need to regrease the pins. My guess though is they will come good after some abuse as suggested above
