hey guys i have a 33gtr and i want to drill some surge holes in my turbo ,,,,,its a t88-34d mostly want it done for the sound it will make can u guys please help
Just get a drill out mate, space them so you can fit around 8 holes in if you want great sound.
That's crap Nismoid....
.......you need at least 10 if you want the sweet sound.
Lol.
Anyway Sam, the holes aren't drilled right through, they go down to a slot which has to be machined in on a lathe, at the height of the lower compressor blades. Perhaps Hypergear could get the slot and holes machined for you? Or can you use a gt35 front and bore it out? I've got a chinese .7 surge ported one here you can buy cheap.
What it will do for performance is anyones guess, do you have surge at the moment you're trying to get rid of or is it purely for the noise? Perhaps a folded gum leaf in front of the compressor would work well? :P
riiiight, so u have tried and proven this then ?
It's a well proven fact that surge slots SLIGHTLY increase lag, they are used on turbos with compressors that flow a lot relative to the turbine side as they are at a higher risk of surge than other turbos. You can't just drill holes in your turbo and expect it to work just like surge slots, it simply won't!
Are you 100% sure you know exactly what surge is and that your turbo is actually surging? If it is the easiest fix (albeit not ideal) is to make it slightly lazier coming onto boost.
I've tested it person that anti surge holes would reduce power to boost ratio and increase lag. I wouldn't run the anti surging setup unless it is surging, and the last thing I had to do to overcome this problem.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
