http://shop.nissan.c...brandCategory/8
I will not be held responsible for any money spent...
Check out the iPhone covers!!!
Kristian, can we organise a "group buy"? or something to buy some merchandise?
Or if not, is it difficult to get this stuff?
N1 handbrake - no leather, like a lightweight BOSS ;)
Ohhh nice.
They say that "imitation is the greatest form of flattery"...
...but this one isn't imitation...
Very fortunate that this was sold privately here on SAU - Good on SAU! :thumbsup:
And many thanks Marcus for Nismo's Opening/Closing Times!
I'm sure they're useful to not just myself.
Bobby, Nick & Luke, I'm going to spruce up the old Nismo Oil Cap and increase its appeal (and value) by double - lol
I only have a small NISMO problem, with the following NISMO items fitted to my car
AFMs
Intake collector manifold (Group buy, on it's way from Japan)
Cluth pedal bracket
RB26 oil pump (not N1)
Instrument cluster
Centre gauges
Leather gear shift knob
Front strut brace with BMCS
LMGT2s
Wheel nuts
Tyre valve caps
Lighter
Braided clutch line
Engine and gearbox mounts
Air filter
Engine oil cap
Fuel filler cap cover
Floor mats
I have the Weldina Version 2 rear muffler (oblong shaped) and it's so damned quiet! Does anyone have a version 1 that wants to swap?
I have a nismo weldinda ne-1... Not sure if that is what your talking about, as it is pretty quite also..
ahh yea i think i remeber the oblong one you guys are talking about...
mine is abit different.. same as the ztune i believe but not in titanium...
That's the same one, the version 2 muffler is oblong, the version 1 is round (and a bit louder apparently). Rear muffler is interchangeable...
Ahh yea, sorry I was confusing it with the muffler tip shape.
Mm interesting stuff, might need to see if I can source one.. I like the sound of mine as is, but it is very quite.. But then again I don't want it too loud either ha.
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
