Over the last coupla years, I've managed to pick up
nismo key, fashion lighter, paperwork case, floormats, clear front & side indicators, fuel pump, billet oil cap, high-pressure radiator cap, timing belt, LM GT4 18" bronze rims, s-tune wheel lug nut set, s-tune air valve cap set, 480cc injectors, solid shifter, dash cluster, engine mounts
I did have the nismo 3-gauge dash cluster, but I've since replaced with a GTR MFD (non-nismo).
All parts have seemed like the highest quality to me. I'm more than happy to buy Nismo. The key was probably the hardest - I nearly picked one up in 2007, but fell through - and recently managed to pick one up uncut. I'm always on the look-out for nismo parts :)
  • 4 weeks later...
Need a keen eye here guys. Looking at buying this Nismo Duracon shifter which looks hella cheap:
http://www.ebay.com.au/itm/NISMO-Duracon-Gear-Shift-Knob-Manual-Black-Nissan-/110878560606?pt=AU_Car_Parts_Accessories&hash=item19d0e0915e
It looks the goods, the packaging looks legit (I own another Nismo shifter) but the price is throwing me off. What do you guys think?
http://www.ebay.com....=item19d0e0915e
i have the same one and got mine for that price through performance wise.. was told it was genuine, looked good in packaging, feels good in the car.. still not 100% its 100% genuine, but it does do the job! and hasnt worn crazily in the 4 months or so ive had it for. so im not really fussed either way. also purchased other parts through performance wise so i tend to believe its genuine.. they may have over stocked them in Japan and now offloading them cheap?
I <3 Nismo gear, it's just faultless
So far I've tracked down and installed
Nismo Ti Strut Brace
Nismo LMGT4's in Silver
Nismo S-Tune suspension
Nismo Rear Member Brace Kit
Nismo Floor Brace Set
Nismo Lug Nuts
Nismo Sports Clutch
Nismo Timing Belt
Nismo Intercooler Piping Set
Nismo Steering Rack Bush Set
Nismo Leather Gear Knob
Worth every cent, the gear is just superb :)
Read the first part of your post and thought the second part haha.
Well if Nismo makes a better umbrella than Alfa Romeo, I think I'll go for it...
Hmmm, but not rubber boots Kristian lol
Is there a more comprehensive catalogue than ^^^ ?
I'm surprised at how many ppl here have such sizeable lists!!!
Yeah, there's alot of ppl with empty walllets after looking throught that catalogue
Better add mine,
Nismo short shift kit
nismo radiator cap
nismo cold air intake
nismo oil cap
nismo oil cooler
nismo n1 vents
nismo brake master cylinder
nismo injectors
nismo clutch master cylinder
nismo suspension link components (various - not complete set-up though)
nismo gearbox mounts
nismo engine mounts
nismo fuel pump
and soon to have nismo mfd v2
Probarly a few more that i've missed...
Edited by wedge_r34gtr
Slightly off topic but how to get...
I can get these easily if you need it.
For my ER34
I have S-tune suspension (Willing to Sell)
Speed meter
S-Tune front and rear strut tower bars
S-Tune front and rear stabilizers
Coppermix Twinplate clutch.
S-tune rear tower bar for R32 (Willing to sell)
Side markers
Probably a few things I forgot to mention.
After oil and radiator cap I'll be complete.
Easy to source if there is stock !!
http://shop.nissan.c...duct/detail/515
More here and I can help with purchase but would advise not to buy clothing without trying on first as clothing sizes are for mighty midgets.
http://shop.nissan.c...itemCategory/50
http://shop.nissan.c...itemCategory/51
http://shop.nissan.c...itemCategory/52
http://shop.nissan.c...itemCategory/61
    • Yes that’s what im trying to decide. Should I do stock gtt box or enclosed or open pod.
    • Also, I note OP is in Melbourne, which begs the question... are you aware of how illegal your car will be with a turbo, and intercooler and any sort of filter change? I don't know how you can get past the "2 intake mods" "rule" that seems to exist in Vic. Fully engineered might or might not get you there.
    • If you have a turbo... then the ducting holes I used to feed the pod are not available because your intercooler likely uses them. If you have an intercooler, your IAT's are going to be goverened by how good your intercooler setup is. I'm yet to really see anyone check IAT with a snorkel/boxed pod/proper CAI versus and unshielded pod. It would be interesting! But I suspect that the differences would not be so noticeable as if you were N/A as the intercooler is where the air is being cooled.. and out in front where the FMIC would be is a pretty good spot for it.. When I was turbo I pushed the stock GTT box as far as I could and made some pretty good power out of it, and noticed on the street I never made the same power/boost. Then I did a before and after run with a pod filter versus the box and picked up about 9PSI from the same boost duty cycle and about 50KW instantly. I never ran the stock box again, and recently removed it for my N/A setup. The box is restrictive to a degree - Even with the V8 setup I noticed I picked up power by removing the box completely, so punching holes from the bottom of it to get air from the passenger guard *helps* but the most effective one in my case was simply having the ducts, a pod, and no box around it. In my experience, *more* air was better than cold air. The air (with ducts) will be cooled off as you start moving, and especially if you start moving fast (a race track). It actually moves around quite a bit as you can see.
    • Well you could certainly buy or build an enclosure for a pod in that corner of the bay. It is absolutely vital that there is a nice big opening to let cold air in to it from the front or underside, otherwise it will just pull air in around the edges from the bay, and if that air is hot, you gain nothing from enclosing the pod. There is lots of good evidence around (including on here, see posts by @Kinkstaah for example) showing that pods pulling hot air from the bay is only a problem when you're static or slow in traffic, and that as soon as you get the car up and moving the air being grabbed by the pod cools down. Although that will obviously vary from car to car, whether there is a flow of cold air to the pod or if it all has to come through the radiator area, etc etc. Obviously, the whole exercise requires as much thought as anything else does. Doing the lazy thing will often end up being the dumb thing. The stock GTT airbox has a cold air snorkel to feed it from over the radiator. Shows that Nissan were thinking. The GT airbox is upside down compared to the turbo one, yeah? Inlet at the bottom, AFM/exit on the lid? That might make it harder to route the turbo inlet pipe using the GT airbox than a turbo one. That would probably be the main reason I'd consider not using it, not that it is too small and restrictive. I'm looking at a photo of one now and the inlet opening seems nice and large. Also seems to have the same type of snorkel that the turbo one has. Maybe all that's required is to make a less restrictive snorkel/cold air inlet, perhaps by punching down through the guard like I did.
    • Also seen this as an option
