Strange.
The nismo s-tune one I have for my R34 GT-T (http://www.rhdjapan.com/nismo-s-tune-strut-tower-bar-front-skyline-r33-r34-bnr32.html) definitely has a brake cylinder stopper. Was a bit of a pain to fit initially because of it.
  • Like 1
That was on yahoo japan. Very rough shape. It's scuffed pretty bad. It seems someone is buying up stuff to resell on ebay. Looks like he snapped a shot with a cell phone from the 90's. I think you can see the japan packaging still like he just opened it lol. I remember looking at it on yahoo it was pretty cheap, I would guess because of condition.
Its no secret nismo omori factory are making these big ti strut bars as per the link jtcc posted http://www.nismo.co.jp/omori_factory/original_menu/ttb/index.html
Ive been quoted about 2.5k aud, they can come with both the nismo and omori factory badges.
My latest nismo purchase should be here on monday, another set of lmgt4's because having 3 sets wasnt enough hahah
Edited by Gts30t
Yea I already have one ordered. From what I hear they make so many, when they're gone they are gone. Then you have to wait like 2 or so months for them to make more.....if they make more lol. That's nuts it costs you guys 1k more. I wish they had the old nismo logo though. I don't know why, I just don't like the new one. So I went with the black omori badge.
Edited by JTCC
On my 33...
Nismo GMAX twin plate clutch
Nismo Clutch Slave
Nismo Clutch Bracket
Nismo GT Pro 2 way LSD
Nismo Tower bar WITH brake stopper
Nismo low temp thermostat
Nismo front and rear lower arms
Nismo indicators
Nismo Brake lines
Nismo Extended wheel studs
Nismo FPR
Going to purchase Nismo F+R Swaybars i think.
Did also have Nismo speedo, Timing belt, Short shifter and knob, B-Pillar trims and 550cc injectors but have been removed for upgrades, Namely Racepak/Attain shifter/HKS Belt/1000cc injectors.
Didn't actually realise I had so manny Nismo parts!
Edited by R31 drift pig
I eyed off the Nismo swaybars, but ended up going Whiteline f+r, as they're adjustable.
Are there any benefits to going Nismo swaybars over Whiteline? Are they bigger/thicker/stronger?
Front Nismo is 27mm, front whiteline is 24mm
Rear Nismo is 23mm, Rear whiteline is 22 mm or 24mm in the motorsport version.
Nismo sway bars are fixed, whiteline are adjustable.
Both around the same $$$.
And Nismo are lighter and djr81 said.
  • Like 1
Thanks Rob and Anthony.
a) 3" system is fine with me
b) wiping the soot off at the end of a run - inside the bell - seems to be advisable
c) the restrictive elbow before the muffler was cut, so the system remains straight
d) I think I bought it off Fb Rob - GTR's n GTR Parts I think.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
