Finally installed Nismo mfd uprade, no more blinking red boost metre.
The factory boost sensors often just fail due to a cold solder joint. There are some posts on SAU about it, and it's a relatively simple fix.
I've had this happen to mine - and was fixed by reflowing the solder on the main connections. It may be worth checking this on your old boost sensor, as it may be still usable.
Yeah i know what you talking about, the normal boost gauge will get stuck on zero and no pressure display, has happened to me before. But Main reason i changed to the nismo boost sensor is because the stock sensor only goes to 1.2 bar and my tune goes to 1.5 bar so at max boost the stock sensor will go past 1.2 bar and start blinking red. Not only is it annoying but you also dont know much boost your making. With the nismo sensor it can read up to 2 bar which was exactly what i need.
A few members here have already paid and secured a set or two for themselves. Thanks Nismo for bringing back the 10.5in!
I guess seeing how much they go for used was too tempting. ETA on production is September with deliveries in October :)
  • Like 3
Wow $4400. You can definitely pick them up for A LOT cheaper!
All Nismo needs to do now is start making those lovely 19in LMGT4's in silver asap
With the conversion of yen to aud and with shipping thats about right on the mark ! If you can get cheaper put me down for a set
Nismo R-tune air duct
Nismo air filter, valve caps and ne-1 gaskets
Nismo iPhone case lol
Very nice. Don't ever use polish on the R-Tune duct. Only a duster or soap and water or Kwik Detailer.
  • Like 1
Looking at the site - they are cheaper than $4400
Yeah they are cheaper on rhd site. Just under $4000 with cheapest delivery, but i think you are forgetting the import taxes that you will get stung which at that price will be around $660
wish the yen was better if you have a better lead I'd be greatful [emoji4]
Even @ $4k + another $1600 worth of semis + matching wheel nuts, plus new coil overs to replace my Std Vspec suspension - I'm getting into the $7k range - gulp. I might be a tough sell to the missus for the weekend car - when I make her drive a 14 yo oil burning xtrail on its last legs... :-)
  • Like 2
    • So either way it is gearbox out and look what is wrong?  I know about the input shaft bearing. Even before swap/new clutch the it sounded exactly like this: So is that inout shaft bearing or the other was installed backwards?  And can some please tell me the part number for that input shaft bearing? The gearbox is small box from R34 N/A and number is FS5W71C. Thank you
    • I am yet to see anyone ever regret a quaife or helical. ...other than drifting/skidpan duties. I kind of want to upgrade my factory helical with a Quaife (but really it's not ultimately that different, and is a MASSIVE UNDERTAKING), that's how good the hype is about them, that I want to try them 'just to see'
    • D2 and Ksport are essentially the same thing and basically just generic Taiwanese manufacture. Better than ChinaBay crap, but... not top shelf. Öhlins have got to be some of the best dampers around, so likely to be a good option. It's going to get to the point though where I suggest you buy from Oz. We have at least 2x excellent options here. If I were you though, I'd be talking to KW about doing something for the R33. There's bugger all difference between that and the 32. In GTR land, anyway.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
