  • Replies 238
Posted Images
Anyone cruising sat morning?
keen to drive with people I know, or don't....
I was thinking Saturday morning but I'd have to leave up here at like 3.30am or something so I'm not sure yet... Would be better to stay down on the Friday night but will work that out in a few weeks I guess
I haven't decided yet either - Trappers is convienent and is the only other place besides Maccas where you can grab a coffee before you get going in the morn. Might try the Bakehouse hotel cause it is $99 instead of Trappers $140.
I would offer to share a room but I snore like a buzzsaw.
Hahahaha yeah well i snore too, so i think ill have to stay in a room FAR away if i come down :P i think staying makes more sense as i would be pretty knackered by the time i hit the track, also gives a chance to get up and check the car etc in the morning i guess...... I'll google the names above, i have a friends place i could stay at 45mins away, but will see how that goes :)
Luke Ill be heading down on Sat morning. I wont be going M7 tho coz I have no etag so it will b Northern Rd to the Hume. Probs leave mine at 5am and get brekky in Yass or something and Through Penrith at about 5:30ish.
Just making sure that u can buy the license needed on the day lol. Ill source a helmet and maybe a trailer.
we stayed at the bakehouse last time Eric, it was fine. In fact I've stayed pretty much everywhere in that damn town and the only places that were really not up to scratch were the Alipine Heritage Inn (really not like it sounds, but it was mostly Pete's snoring I think), and the Pelican Sheep Station. There are some places that are a bit expensive for what they are, so the smaller places like Bakehouse are good.
Great to see you filled the day Pete....now book another one closer to the end of the year so I can have a go!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
