Cheaper? I prepay and that brings the fees down a lot compared to direct debit. $700 for 15 months...not the cheapest...but all the gyms in my area are more than that and anything cheaper is starved for equipment choice :/
chuck up the gym company aswell guys...just good info for others looking.
Reasong I started this thread is that im currently in the army so I have a free gym, but im looking to get out next year so have to start looking around for a normal gym where I have to pay. Rather than getting the marketing runabout and constant phone calls, your knowledge will no doubt help me and many others.
Keep it comming
This.
Although I might be going to another gym.. sorry Troy
It's all good, you want to train with your boyfriend. I understand. He is the man in the relationship after all, so you kinda have to do what he says.
:P
  • 1 month later...
Well my gym is called PTC Frankston.
Its more like a club than a commercial gym, you cant simply walk in and train, and you cant buy a membership unless I like you, so you need to train for a few weeks
We have the best equipped strength facility in Oz, we want for nothing
So because I limit how much I can make, the clients pay more, which theyre happy to do
Prices range from $20 a session/$40 week/$1300 year
These prices include coaching every session, no PT's
To be coached by yourself (among others I figure) I'd pay the $1300 in a heartbeat, if I had some amateur competition aspirations. Hell, even if only for short term - the knowledge gain would last a lifetime.
ftmfw bitches
like pirating, its hard to go back to paying something you enjoy it for free
Keep it comming
Yep gotta love the free shit :D
Paying $49.95 at Anytime Randwick. Since it's a new gym, all the equipments are new and no ullehs to scream in my ear!
If you want to get cheap memberships at Anytime, one way is to get their foundation memberships. Or sometimes they have offers to foundations members to sign up mates at the same rate.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
    • Good work to think to check that, and thanks for coming back to post up the outcome.
    • Given it happened suddenly, and when you come on boost, I'd check all your inlet - hose clamps in place and no split rubber or silicone hoses. Even the hard to get to ones near the intercooler. It's possible air that went past the air flow meter is being dumped out a big hole.
