So what ballancer do the japs recommend or use as prefference.?
In regards to rev limit, do you mean set it real high so you dont hit it?
What happens if you manage to get it to spin to the higher limit, wouldnt that be worse?
Your better off setting I higher limiter then bouncing off it.. What Paul said is ideal though
Damn... how will I be cool without banging and flames n shit?
But I never really hit limiter, only by accident...
So theres nothing bad about it hey?
Well lets say you set the "Hard cut" at 8600 RPM, and you start pulling timing from 8300 RPM but aim to change gears at 8000 RPM it won't make a difference as you're never in that bit of the map anyway. If you do find yourself up there, the car will feel sluggish, so you change gears.
He has a RPM limiter for 0km/hr of 1000rpm, it's no his fault :)
ohhh, so its gonna be like that is it.... ;)
Really?!
RB30's love dirty big launches. Dial up 8000rpm, drop the clutch and get ready to grab 2nd before the limiter :D
You sir, are not right in the head. 8000rpm and drop the clutch?? That thing of yours must love the abuse.. and your car does too.
Get a real ECU. :) Motec randomiser and soft cut allows you to pick a RPM window to cut. So if you set a 300rpm window it could start to cut some cylinders a 8000 and increase to full cut by 8300rpm. The wider the window the more gradual the cut.
Give me a fair run at powercruise and I may stop the trolling... maybe haha
I think he has Microtech? That's a real ECU *cough* carby *cough* just joke piggaz xoxo
I'm sorry but I have to disagree
Carbies do a much better job. True story
  • 2 months later...
Quick thread revival.. Just wondering how the OP went in the end? Did you fix your problem??
I will find out within 2 weeks when I hit the track, I machined front lip on balancer down to 1mm over belt height, and bead blasted all the shiny black anodising off the belt grooves. I went back to the strip and did the same things that spat it last time, it stayed on. Will know for sure after I get to track. Ill keep you posted
I dont know about the OP but my Ross balancer was spitting powersteering belts, we slotted the powersteering bracket so it came 5mm forward and now after 5 trackdays and 3 drag days its all good.
Mine is a 25/30 also, using the 25 bracket and pump.
I think it has something to do with either using the powersteering pump and bracket of a 25, 26 or a 30.
Or I could be totaly wrong.................
    • Thank you, 100% the intent. New coils were due and the 17" sixers look/feel loads better than the stock wheels. The aero options are so spot on.   Thanks for the warm welcome, all!
    • 98 r34 gtt Been rocking my latest setup and car running like never before. Have put a good 200 miles on it since all the latest changes and additions. everything is dialed in and have been driving it a bunch.   However, all a sudden last weekend as soon as I pushed throttle passed 4k and the engine stumbles, (slow or fast acceleration) hesitates and doesn’t go above 4100 or so, like a misfire. Everything else seems fine. I had a “good” set of coil packs that I removed from car when I first got it when I changed them over to new coils. I swapped out current ones for those, but no change. I also changed the plugs, no change. Seems to rev over 4 when out of gear with no load just fine no “misfire”, but as soon as its in gear with a load of any kind, it “misfires” as soon as rpm drop back below 4 k it runs perfectly, smooth, starts, restarts and drives fine as long as I keep it below 4 k while in gear. All readings look fine, no CEL   Any idea as to what could all a sudden cause an issue when pushing rpms passed 4 k?
    • When you say your cams are 272/262 is that 272in and 262ex?
    • We're arguing semantics. I am saying 45 accel and a 55 deccel ramp are "2 ways". Even a 45 degree ramp and an 89 degree ramp is "2 ways", because it is literally... two ways. The cusco 55/30 ramp is a 2 way. It's two ways. I get it though - in normal nomenclature a "2 way" would be 45/45 or 55/55 or 60/60 i.e the same locking in both directions. And something like 45/65 would be considered "1.5 way". I would then say if we're getting into the nitty gritty then every locking diff is a "2 way" diff and we should not speak in 1.5, or 2 ways but ramp angles instead. Which ofc if one of those ramp angles is 90deg, that side is not doing any locking. :p So Nismo don't obviously sell 3 things. The fact of the matter that they only sell two items really goes to show that there's a 2 way and a "1,5 way" which is really a 1 way. I believe the actual lockup for the 'adjustability' of the GT pro is really just setting preload for when the ramps actually start locking up. It's not changing how much 'wayness' there is. It is (somehow) horribly explained. People just buy whatever diff and go "locks up good bruh" and that's what ends up on socials forever.
