Do you mean the pulley's are not at the correct offset for the pump?
Or the V grooves have incorrect angles, or are to shallow or deep?
More info please.
The offset was off using a 25 pump and bracket on a 30.
Oh so you mean you used a balancer that is designed as a factory fitment but put it in an application that it was unintended for?
Is anyone having a problem with a 25 balancer on an RB25 or a 26 balancer on an RB26?
I'm having a problem using a 26 balancer with 26 power steerin pump and bracket on a 2630. Bear in mind this problem did not exist when using the ATI. Mark Berry had same problem.
Piggaz also was having same issue which I think was 33 balancer on RB26 (2.8) with correct power steering pump etc. No prob prior to fitment either. Correct Paul?
I was having a few issues with this flicking off PS belt thingo. We made sure everything was "square", IE the PS pump/bracket was spot on and I also fitted the idler pulley thing for the belt. Problem went away. Car will be back on the road soon so I'll be able to report back.
If the pulley is underdriven u need a smaller belt. Even my ATI spat a belt. I put a smaller belt on one that only just went on with ps fully loosened off and no probes now. try get as close to the crank as u can that's what I think.
They're the same size as standard.
Were you using a 25 balancer or a 30 balancer?
I believe it was a 30 one.
But don't quote me on that.
I was pissed it happened, BUT, these things happen when you are using different parts from 3 different engines, I like to call it teething problems.
I'm using a ross rb25 balancer with rb25 pump with their idler pulley kit and aligning the pump as per Ross's instructions and still throwing belts. it was never a problem before the new balancer so there must be something going on
Get a straight edge and run it from the balancer to the PS, I found the difference to be about 5mm, we drilled out the bracket so the whole PS assembly could move forward 5mm, the job took a couple of hours to do but now the 2 pulleys align perfectly.
And it was only the PS that was causing issues, the AC and ALT are fine.
Give ROSS a call and see what they say, its a common problem, albeit a easy fix if you modify the bracket.
Something is really wrong if your throwing belts with the idler pulley kit...
More elaboration, I can confirm that on the track I failed to spit the powersteering belt again. Mine is rb25, limiter 7700, to recap on the mods I did to help, I machined front lip of p/s section down to 1mm over belt height, and beadblasted all the anodising off the belt grooves, and refitted using a new gates racing belt. Time will tell if its a confirmed win
That's good news Amon.
I asked Ross some months back if he thought it could be the coating - as he insisted there was no difference (measured up) between the ATI and the ROSS. I wonder if perhaps the anodising is somehow making it "grip up" ?
Mine already had been machined down from Ross - this is something they had already struck apparently. Interesting that yours which I assume is not as old as mine, still had the lip...
Yeah iv only had mine since the start of this thread. could of been old stock... I recon the anodising makes the belt intermittantly slip and grab and create a flicking of the belt. Might be wrong. whereas the blasted pulley is very grippy and consistent
I am coming down to the nit and gritty part of my build, and saving the power steering belt issue for last. I have run a dry sump oil system on my RB26/30 build and I cannot risk having this issue, so I am going to correct/fix the issue first, before it even becomes a problem. (save the "If it ain't broke, don't fix it" comments please). I don't want to have a catastrophic engine failure due to an f**king power steering belt.
I am running my 2 year old RB26 Ross Dampener on my RB26/30 build, don't see a problem using it. I am either looking into the Ross Idler Kit, or this other kit they have.
http://blog.rossperformanceparts.com/category/engine-protection-kits/nissan-rb26/
Anyone running a dry sump have experience with this type of set-up? Anyone see any issues running this kit? Any input would be greatly appreciated.....
If not, then just to avoid the whole issue, I am gonna run a Volvo Electric Power steering pump.......
I've done a couple of HTD driven steering pumps with Ross
Never had a single drama with them. Slows the steering pump to 50% (or whatever speed you choose to gear it) perfect drive and never had a belt come off. After we fitted the first kit and made some recommendations to Ross I believe he has refined the setup and is supplying some specific fittings and spacers that are needed now.
    • Well, I can recommend the partial AV system translation CD I ordered from Car Audio Workshop in NZ. Whilst it didn't address the date issue, it has conveniently translated on-screen menu items into English, and now allows the GPS-received time to be offset in hours rather than minutes, so I can display Eastern Australian time accurately ( and bump it by another hour when daylight savings starts ).
    • Yuh, if it's 45°C outside, my car is driving in it.
    • I'd be curious to hear more. Otherwise, have you driven a modern x-trail? I wonder how it compares. Here in Australia they are/were popular for rentals and fleet vehicles. I have been in some and my impression was they are bad. But, this may have been very different in the 2000s at a good trim level. Twenty years is plenty of time to make the model worse. I do very much agree with the 2 silver cars in the garage approach. But, not driving because it's too hot would not leave a lot of time in the year for many Australians. I don't think you need to worry too much unless the car has actual issues with overheating.
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
