Do you mean the pulley's are not at the correct offset for the pump?
Or the V grooves have incorrect angles, or are to shallow or deep?
More info please.
The offset was off using a 25 pump and bracket on a 30.
Oh so you mean you used a balancer that is designed as a factory fitment but put it in an application that it was unintended for?
Is anyone having a problem with a 25 balancer on an RB25 or a 26 balancer on an RB26?
I'm having a problem using a 26 balancer with 26 power steerin pump and bracket on a 2630. Bear in mind this problem did not exist when using the ATI. Mark Berry had same problem.
Piggaz also was having same issue which I think was 33 balancer on RB26 (2.8) with correct power steering pump etc. No prob prior to fitment either. Correct Paul?
I was having a few issues with this flicking off PS belt thingo. We made sure everything was "square", IE the PS pump/bracket was spot on and I also fitted the idler pulley thing for the belt. Problem went away. Car will be back on the road soon so I'll be able to report back.
If the pulley is underdriven u need a smaller belt. Even my ATI spat a belt. I put a smaller belt on one that only just went on with ps fully loosened off and no probes now. try get as close to the crank as u can that's what I think.
They're the same size as standard.
Were you using a 25 balancer or a 30 balancer?
I believe it was a 30 one.
But don't quote me on that.
I was pissed it happened, BUT, these things happen when you are using different parts from 3 different engines, I like to call it teething problems.
I'm using a ross rb25 balancer with rb25 pump with their idler pulley kit and aligning the pump as per Ross's instructions and still throwing belts. it was never a problem before the new balancer so there must be something going on
Get a straight edge and run it from the balancer to the PS, I found the difference to be about 5mm, we drilled out the bracket so the whole PS assembly could move forward 5mm, the job took a couple of hours to do but now the 2 pulleys align perfectly.
And it was only the PS that was causing issues, the AC and ALT are fine.
Give ROSS a call and see what they say, its a common problem, albeit a easy fix if you modify the bracket.
Something is really wrong if your throwing belts with the idler pulley kit...
More elaboration, I can confirm that on the track I failed to spit the powersteering belt again. Mine is rb25, limiter 7700, to recap on the mods I did to help, I machined front lip of p/s section down to 1mm over belt height, and beadblasted all the anodising off the belt grooves, and refitted using a new gates racing belt. Time will tell if its a confirmed win
That's good news Amon.
I asked Ross some months back if he thought it could be the coating - as he insisted there was no difference (measured up) between the ATI and the ROSS. I wonder if perhaps the anodising is somehow making it "grip up" ?
Mine already had been machined down from Ross - this is something they had already struck apparently. Interesting that yours which I assume is not as old as mine, still had the lip...
Yeah iv only had mine since the start of this thread. could of been old stock... I recon the anodising makes the belt intermittantly slip and grab and create a flicking of the belt. Might be wrong. whereas the blasted pulley is very grippy and consistent
I am coming down to the nit and gritty part of my build, and saving the power steering belt issue for last. I have run a dry sump oil system on my RB26/30 build and I cannot risk having this issue, so I am going to correct/fix the issue first, before it even becomes a problem. (save the "If it ain't broke, don't fix it" comments please). I don't want to have a catastrophic engine failure due to an f**king power steering belt.
I am running my 2 year old RB26 Ross Dampener on my RB26/30 build, don't see a problem using it. I am either looking into the Ross Idler Kit, or this other kit they have.
http://blog.rossperformanceparts.com/category/engine-protection-kits/nissan-rb26/
Anyone running a dry sump have experience with this type of set-up? Anyone see any issues running this kit? Any input would be greatly appreciated.....
If not, then just to avoid the whole issue, I am gonna run a Volvo Electric Power steering pump.......
I've done a couple of HTD driven steering pumps with Ross
Never had a single drama with them. Slows the steering pump to 50% (or whatever speed you choose to gear it) perfect drive and never had a belt come off. After we fitted the first kit and made some recommendations to Ross I believe he has refined the setup and is supplying some specific fittings and spacers that are needed now.
    • To expand on this to help understanding... The bigger/longer the block is, the more it's going to work to sit on your far away high areas, and not touch the low stuff in the middle. When you throw the guide coat, and give it a quick go with a big block, guide coat will disappear in the high spots. If those high spots are in the correct position where the panel should be, stop sanding, and fill the low spots. However, using a small block, you "fall off" one of the high spots, and now your sanding the "side of the hill". Your little block would have been great for the stone chips, where you only use a very small amount of filler, so you're sanding and area let's say the size of a 5/10cent piece, with something that is 75*150. For the big panel, go bigger!   And now I'll go back to my "body work sucks, it takes too much patience, and I don't have it" PS, I thought your picture with coloured circles was an ultra sound... That's after my brain thought you were trying to make a dick and balls drawing...
    • Oh I probably didn't speak enough about the small sanding block for blocking large areas.  In the video about 3 minutes in, he talks about creating valleys in the panel. This is the issue with using a small sanding block for a large area, it's way too easy to create the valleys he is talking about. With a large block its much easier to create a nice flat surface.  Hard to explain but in practice you'll notice the difference straight away using the large block.
    • Yep I guessed as much. You'll find life much easier with a large block something like this -  https://wholesalepaint.com.au/products/dura-block-long-hook-loop-sanding-block-100-eva-rubber-af4437 This is a good demo video of something like this in use -    You have turned your small rock chip holes into large low spots. You'll need to fill and block these low spots.  It's always a little hard not seeing it in person, but yes I would go ahead and lay filler over the whole area. Have a good look at the video I linked, it's a very good example of all the things you're doing. They went to bare metal, they are using guide coat, they are doing a skim coat with the filler and blocking it back. If what you're doing doesn't look like what they are doing, that's a big hint for you
    • The odometer does go up when driving.  Does this tell it is an issue with the speedometer itself?    Where can I look for replacement cluster? Or speedo? I can likely do the repair.. Will ER34 cluster work on HR34? Or do I need a HR34 20GT S2 specifically lol
    • Mine's a bit bigger at 70x150mm roughly. The spots are flat, just can feel the edges if I dig my nail into it. I did fix some other other ones by both using my finger to sand that small spot (I'm a bit wary of doing this and creating hot spots and a bigger mess) and I also did sand over it flat and others, but this also worried me a bit because if I create an overall low spot on the panel on paint that is good.  Correct me if I'm wrong but as long as it's flat even if I can feel the edges, I can put filler because it will all be level once I sand it? I can see myself going in a circle after sanding guidecoat with 320 grit if for example the panel is flat with my hand but because I sanded the guidecoat I could have created a low spot again somewhere. Unless where I'm going wrong is what I mentioned previously where I didn't go low enough on the grits. It's 1 step forward and 2 step backwards here haha. I'll probably need to experiment with it more. Last time I go back to bare metal lol.
