Skyline r34 gtt (rb25det neo)
I just installed some tomei poncams type b 260 degrees 9.15mm lift and as stated by tomei no need to upgrade the valve springs.
i also installed the adj cam gears but only the exhaust side would fit, intake cam gear didnt match the intake camshaft. so i just used one old and one new
the timing is perfect and the knock is only on idle and coming from the exhaust side.
at first i thought it was the CAS but not too sure.
im running stock afm and injectors at the moment but will upgrade once the knock has gone and it hasnt been tuned yet but that shouldnt cause a knock.
any help or suggestions would be much appreciated.
https://www.sau.com.au/forums/topic/404757-tomei-poncams-type-b-engine-knock/
If its an r34 neo engine, it has solid lifters
This!!
They should be a drop in application, if you have done that and have the Ex gear set right it should be fine... Mine are sweet :)
This!!
Just for future reference, whilst they may "drop in", valve clearances should be checked and re-shimmed as required.
Yep, nissans clearances will be a better guide. and 'close enough' isn't good enough either keep in mind too much it'll slap the valve up and slam it on seat, too little and the valve wont get enough time on the seat to cool.
Actually the initial/final ramp rate has a lot to do with choosing clearances.
Having said that, going from Nissan's 0.2 - 0.25 sort of clearance to the 0.45 territory suggested by Tomei sounds like madness. You might add 0.05, not more than double.
Edited by GTSBoy
Don't trust those stickers, as part of compliance there has to be a sticker mentioning timing, clearances etc. Well mine says BTC of 15degrees (RB25), which if you know RB26's actually run a BTC of 20 degrees.
    • I used to have Walbro 255's when they were a pretty common update. (or were they 044? 040?) In any case I had a dirty tank. I thought the tank was good, but I would find the filter would clog in maybe ~50km of driving. If the issue persists, well, your fuel system or tank has crap in it that the pump is sucking up.
    • Hi. Ok thanks for the info. I/we do not know what tune is on that Nistune ECU so it is why there is stock ECU and that Nistune is for later when the car is done. I have guy who tunes Nistune and other ECU so i will then take it to him to see and properly tune for the car   And for the update. On 99,9% it is bad fuel pump. Which is wierd cuz it is like 2 years old(brand new walbro 255) and that filter (also brand new) was dirty.  I was alwaya pumped premium(100) on very good petrol station so i dont know how is that possible...
    • Dear folks My family members have 4 different cars : Triton 2015 and Corolla 2011 and Mazda3 2012 and Hyundai Elantra 2014 Looking to buy engine oil funnel spill free What I found are are below  https://www.amazon.com/gp/aw/d/B0BBTTJNKX?ref=ppx_pt2_mob_b_prod_image&th=1 https://www.ebay.com.au/itm/145553221359?srsltid=AfmBOoqYBU6Ptw0LU_bAp_k67U3qkF97HHvePkA7iHZw8vUmiwoIRaRr https://www.amazon.com/gp/product/B09X23TCS5?th=1 Is there a funnel with attachment that fits most cars ? Don't mind to spend for a decent quality  Thx
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
