My S1 1995 has it, ABS is good, Ive never flat spotted a tyre on the track, why, ABS, why would you want to get rid of it ?????
Unless its a BALLS TO THE WALL race car
I was told there is a wire you can disconnect to disable it for motorkhanas so you can do J turns and stuff.
ALSO IF THE CAR IS REGOED IT WILL BE A MAJOR DEFECT, you are removing safety gear.
LOL! ^^
Totally agree. No reason to get rid of it unless its a serious track car. You rarely ever panic brake on the track either. And panic braking is where you need it.
But im sure in a sec there will be a whole lot of Non ABS users saying they have superior foot control and can make their cars brake to maximum limit without skidding therefore its better than ABS. But the next time a kid/car pulls/walks out infront of you @ 100KM/H and you have 0 time to think, let us know the result. hehe
I have a S2 without ABS. But then again I have superior foot control and can make my car brake to maximum limit without skidding therefore its better than ABS. Just yesterday I had a kid, or was it a car?, pull out in front of me while I was doing 100km/h. I swear I had zero time to think about it and slammed on the brakes causing the back of my car to step out a little but luckily I came to a quick stop and missed him (or her, or the hermaphrodite in the car). A good result I think.
Edited by simpletool
I'm no expert, but I was always under the impression that R33 series 1 had no ABS and R33 series 2 did have ABS.
Series 1 did have ABS, very rare, I have seen it, also have seen series 1 with Airbags, they look like the S14 Series 1 airbag wheel, super UUGLYYYY
Indeed no expert. Comprehension is also not a strong suit - see the previous posts to yours.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
