Hey Guys
Car: 1997 R33 S2 GTST
Tyres : 265's x9 rear and 235 x 8.5 front and decent tyres as well
Suspension : Pedders Coilovers
Ok so im under no impression that im a great driver by any means but now I spin out ALOT.
I span two weeks ago ( a full 180degree spin) when going around the roundabout in the wet. I went around it quite slowly(factoring in that it was wet and in driving a rwd car) but I still span out. It took me by surprise as I was being cautious and didnt expect this so I span without correcting . Was doing about 40km/h.... first thought was I hydroplaned....
Yesterday it was pouring again , remembering my last experience I went even slower this time , but wasnt taking a right like before and was going straight through the roundabout , so a slight turn of the steering wheel was all that was needed. I was doing about 35km/h. Without warning after i turned , the back end slipped out,this time i was more prepared....so i corrected but my god that took me by surprise.
I dont feel i have the skills to get myself out of trouble should this happen again with traffic around....
What would be cause this to happen? Coil overs? My missus car can go straight through a roundabout in the rain doing 40km and not spin out....why is the line so shit in rainy weather....to the point of being dangerous
This has only started happening since i got coilovers(which virtually eliminated body roll)...im quite sure that the act that I have a much lower center of gravity has something to do with it but how exactly... whats the physics behind this? I assumed having no body roll was a good thing , but now in the wet I have to take corners slower!
And what can I do to avoid slipping out in the wet all the dam time - already have fat 265's in the rear
Cheers
https://www.sau.com.au/forums/topic/407716-so-i-spun-out-again-wtf-is-going-on/
  • Replies 121
Hey Guys
This has only started happening since i got coilovers...
Cheers
This must be totally unnerving for you whilst you have a car that would predictably corner much better than most.
Obviously you had Pedders supply and fit these coilovers?
Did they tighten everything up?
Have you had your wheels realigned by them too?
Did they do a complimentary multipoint check?
It sounds like there's basically no weight transfer at all in your set up.
If your springs & shocks are too stiff; you'll get no warning when it's about to break away.
No body roll is not necessarily a recipe for good handling; there has to be some compliance; otherwise the car won't absorb any bumps, it just bounces over them.
No wheel on the ground; no traction from that wheel. Doesn't matter how wide your tyres are then.
Do the coilovers have adjustable damping? What are the spring rates?
I'm better you have poor tyres combined with suspension too hard makes for a difficult life.
I could drive my GTS-R in pissing rain, with 245/255s on the rear and 370rwkw - not having an issue at all with spinning out. The suspension was as hard as a rock with virtually no movement in it at all (12/10kg springs). Difference was I was spending $300 a tyre.
My money is on shit tyres. What are they?
Pedders coilovers arent harder than some jap spec ones. So Im declined to blame that.
My mates 32 had a problem with spinning around spontaneously, but his hicas light was intermittently on. So we blamed that.
But for you, Get some better tyres. Or go and do a defensive driving course, as you will hurt yourself or worse others. You need to learn to drive that thing.
Do you accelerate out of the roundabout when this spin around occurs?
When you think about it, 40km/h is bloody fast on a tight roundabout.
Skinny tyres are far better in the wet. Wide, cheap, worn tyres in the wet will grip as much as a bucket of eels in whale snot.
Wouldn't be suprised if someone has taken the swaybars off the car.
Also, get under the car and have a look at the chassis rails and make sure theyre nice and straight.
maybe who ever did that threw them over a Nissan Dealer
My liner was shit in the wet, used to slide stupidly without wanting to but nothing some counter steer wont fix,
changed to Federal 595RSR's and its been sticking very well im comfortable enough in the wet to
give it some where i wouldn't have before.
Taking the swaybars off will actually let the car float around a little more.
I know a few GT-R owners who will drop/loosen the front swaybar if it's really wet at a track day to get more weight moving :thumbsup:
Front and rear strut brace and sway bars make a huge difference and some great set of tyres.
These stiffen the car up, especially with stiffer/upgraded rear sway bar, which tends to reduce under steer thus promoting over steer.
90% of it sounds like your skill as a driver. Skylines are tail happy cars, poor tyres, wide tyres, and stiff suspension definitely won't help. But they're just tail happy by design.
Tips: Corner as smooth as you can, don't jerk the steering wheel (I'm sure you're not JERKING it per say, but just try and be more smooth); and practice smooth throttle control. It'll still be a little difficult to control as stated above they're just a tail happy car. But in the wet you simply just have to have to drive like a grandma. Smooth throttle, smooth steering and you'll be fine.
There also becomes a point where wide tyres don't help you in the wet, I'm not sure of the exact threshold... but yeah there becomes a point where it's actually detrimental for grip in the wet.
edit: Or just buy an AWD car. :D
Edited by RB25PWR
This.
I went from driving a WRX to a Skyline and knew nothing of the oversteer.
After you realise how little throttle you need to get all Tokyo Drift, you adjust your driving style.
So in conclusion.
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
