Ev's - R32 Gtr - Targa/sprint/hill Climb Build
Oh scotch locks, you mad!! i had the worst time removing plenty of them in my evo after having power issues with everything that was added to the car by the previous owners.
i've had one of them Ruzic controllers in the box for 3 years really need to install it soon
Warm up lap second session around...........guess where the engine started to fail....perhaps I didnt really need to downchange a gear and overrev the engine on warm up....I feel sick watching this replay.......
Shattering. Golf R driver thinks they've got your measure now.
I kept tilting my head back to try and see over the dash! Camera needs more legs! Least of your worries at the moment though!
I reckon the engine sounded a bit gravelly right from the start. It's not like you were caning it when she went pop.
Eek...sorry to read/see you popped an engine
Highly doubt its the cause but its never good going into Honda and popping the clutch to get it back to 2nd and pinning the revs. Best get plenty of practice on how to row back through the gears and in the future with a healthy engine its often over revs on down changes that take their toll on healthy engines
yes very shattered. will be practicing hard when next out about. its the first real track daying I have done so heal and tow does not come natural.....will keep at it though.
  • 3 weeks later...
Car is now at track art getting some door liners, rear shelf and drivers foot rest.
Also installing heat shield between exhaust and floor pan to stop nav's boots from melting to the floor!!! And a floor plate on NAV's side to cover transfer case area.
Andrew is going I make a custom insert panel to mount the ruzic controller nice and clean.
I also bit the bullet and purchased a reconditioned 6 speed h pattern Trust/quaife dog box off one of the forum members from Sydney. I was going to buy a PAR gear set but after reading forum posts on them I decided to pass on them due to major ????? On them. Hopefully the trust box will go nice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
