I have to agree Scotty.The manual conversion is probably the only way forward for your goal/s to be met right now, & the Z box looks like the least hassle.
Maybe a half decent solution for the RE5 can be had in the future with some electronic trickery (not me either - I'm too busy to look into it right now). No real point in you spending too much effort there when it won't cut the mustard regardless.
  • Replies 70
Yeah, can't imagine an off the shelf box controller. I know the ECU tells the gearbox line pressure commands, becuase I have the uprev that allows me to alter them, however that is just one map in what I imagine would be 5 or so different maps for various aspects of the gearbox.
I don't know what is stored in the ECU, and what is stored in the GB ECU. There is a hell of a lot more to it than just the line pressures.
The main problem is keeping it out of limp mode, keeping the camshafts and throttle operating.
Manual 6spd should work if I leave the AT ecu there and trick it, otherwise there may be a link G4 going in. ;)
  • 4 years later...
off the shelf.. yes http://automatictransmission.com.au/shop/compushift-nissan-re5-automatic-transmission-controller/
but at half the price of my car i think not
On 29/12/2016 at 5:11 AM, Rahil said:
Hey Scott.
I'm in the process of buying up all the parts needed to do a 6 speed swap on my m35. Just wanted to see if you have any advise for me.
Besides the parts required in that link Josh shared of my build i'd not go manual without also be keeping in mind throttle issues. Driving my M35 as manual with the standard electronic throttle was very painful.
Cheers
    • What bedding in procedure did you use?   When you say stutter, what exactly do you mean? Like it feels like someone letting go of the brakes momentarily and regrabbing them again to get you to stop? Re-reading your post, and that is what it kind of makes me think you're explaining, like theres a little bit of a jolt, likely just as you're reaching a stop. I've only had this issue once. And if its caused by what caused mine, you will want to get the car up on stands again and check it over. Mine was a case of a caliper mounting bolt coming out and letting the caliper rotate on the other remaining bolt and gave play in a wheel as it came to a stop. But not every stop either!
    • Yeop... binned it   This will be a summary will not many pics atm and cbf  Fixed the samsonas - it was totally munched Put a new precision 7675 T4 on with proper split pulse mani Got to Sydney to get to car - drove to canberra to get racecar - drive back to sydney that night Next day all day at Plasmaman putting on new clamps cleaning some things up and adding another large engine oil cooler sitting at the rear above diffuser to keep things cooler Next day - Tuesday - on Dyno - killer wikid awesome pumped out really good numbers - more mid range and on lower boost levels Wednesday - first prac - all day again getting the suspension right - had to borrow front suspension again - out do a lap come in - out do a lap - in - what i had just couldnt handle the load at the more consistent higher speeds - got a lap in at the end of the day that was pretty reasonable  Put it this way that lap wouldve had me in 4th in Pro am for the whole event - with only 700 hp and used tyres Thurs first official prac day - lap out warm up - then entered a hotlap with above setting and 80% effort took corners 1,2,3 and into 4 car felt awesome -  rear came around out of nowhere bang into the wall near front on at whatever 140 kmph Done, over, gone Just one of those how did that happen apparently as all indications show nothing out of the ordinary Got to spend the rest of the time at the event like I hadnt done before - was actually Ok mainly as I had my family and my boy is 9 and got treated like a rockstar Long trip home, lost a trailer wheel in nowhere land, X5 airbag suspension gave up half way across nullabour and rode on bumps stops (its now completely fine) had to do a 19 hr drive day on day 3 as accommodation got screwed up so just had to keep driving till found a town with some Now to reassess - hopefully the motor and other things are OK but yet to be seen too. There is no easy fix there is no i'll just order that part and get it sent - we'll have a talk to people see what can happen and what the go is but at minimum its rebuild from scratch struts forward and alot of time effort and $ should and if I return and if but maybe/ when  I have the cage tied into the front strut towers - if I didnt have that things couldnt been worse you can say its just a front end but if you know what goes into these cars... you'll know what that actually means in reality   Car was very fast. Disappointing we just didnt get to show it Effort doesnt win you races though     Apparently this is motorsport !
    • Thanks, will do that.  Thankfully they still feel great.
    • Yeah man, absolutely. You can try pushing me all the way in swapping the R34 for an E9x M3
    • It's almost certainly going to be some amount of pads compound transfer onto the rotors. It will probably go away after you've run them for a bit. If not, pull it all out, lightly sand the rotors, scuff the pads, and rebed.
