  • Replies 175
Pretty sure you have Long and I wrong in the results... I was running as 41 and he was running as 42. We stuffed up the numbers but stayed consistent. I was the one that WD'd the last session
So you two are simply in each others spot? If so, credit to Josh, you beat Thai.
well im happy :cool:
almost broke the 50s barrier on the long wang :ermm: no way
Pretty happy with my result :banana:
Now to try stay in the top 10 next deca!
:woot: So happy with the results!! Wooh!
You three did awesome. Jake.. you need a co-driver. Jett, you need a turbo car ;) Maaaark. 7th is damn good in your boat.
ps. in theory - i beat you all. Again.
Consistently fast times mate. You would have had another 90 points if you could remember where to go. Reality trumps theory though ;)
Bloody happy with my mega mini and long wang times! Next time I'm rolling on rims that aren't worth quite so much and have a bit more side wall :D
Whats this mean for the s13?
over all i am pretty happy considering i was driving a taxi... cant wait to see the difference in times when i bring my datto... Build update is i have got the new struts and brakes, castor bars and all i am waiting on is the control arms now... so close to ready yet SOOO far!!!
LOL yeah my brain is seriously cactus. I'm so excited when i nail a launch my brain goes "well you aced that, f**k the rest and do 4wd donuts"
I'm going to actually study for Dec. Watch out Mike/Ryan/Reon/Rollover - IM CUMMIN FOR J000!!!!
homo.
totes homo.
http://www.3news.co.nz/Australian-politican-says-beastiality-could-follow-gay-marriage/tabid/417/articleID/269838/Default.aspx
ERMAGERD DERKS!!!!
I might even be there in the R32 to wipe the floor with you and your 4wd boat. Or I might be in the drift car which means, WHO CARES! DOOORRRIIIIFFFFTTTTOOOOOOO!!!!!!!!!!!!!!!!!!!!!
Pretty happy with 22nd in the ute! Beat lots of Evo's, skylines and silvia's haha Did ok considering it's like 550kg heavier than the car I normally drive round at Deca lol. So much harder to change directions!
More importantly you won the burnout comp at the end!
Haha and a trip to Ford for some warranty work lol
Me - "Why are you scrubbing the rubber out of your guards?"
*watches Russ make a 5cm pile of rubber chunks on the ground*
Russ - "Warranty claim"
Me - "Yeah good luck with that"
P/S pump is growling at me. Something to do with 2nd gear RL lock to lock haha.
Last time I was 'getting rid' of some old tyres and the power steering pulley wheel snapped off. Got it towed to ford with the belts hanging out of the rear tyres and I picked it up the next day all fixed :) No bill :)
Have you had any issues with your diff Russ? A mate is currently having his fourth fitted (FG XR6T Manual Ute)
What's the issue with his? Is it lowered? I've got a humming noise between 105 and 110. No problem above or below. It's done it since I lowered it. I've just ignored it.
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
