Yeh its probably the same as your in terms of response but definitely there is a top end. It's just kept pulling on top end.
Yeah true, -9's give you good top end with the response of the -7's.
Your engine looks nice and clean as with Mine's Purple colour.
Nice bay callan, love that manifold and turbo setup. Who made the manifold? U though about putting the washer bottle in front of the fuse box?
Just relocate it to the boot like mine :P When you break heavily the transition spurts water out the sprayers
This catch can set up, do you have anything else running to it that i cant see? or are the two top pipes it? it can be done this way because u have a filter to the atmosphere correct?
Anyone
This was yesterday, metallic silver goes down first then the translucent candy apple over the top. Obviously it gets darker the more you apply it.
hot mate!
are you a spray painter by trade??
Also rb25 and 26 coil covers are they all plastic??
rajab damn!
Not a massive job to get the 26 covers on bud. I had them on my 25 and loved it!
Main issue is the PCV as on the 26 covers, there's nowere to plumb it. I deleted my PCV so was a non-issue for me. Other than that, pretty straight forward :)
thanks mate... i just have a long list to do to finish it before Aug. was hoping tidying up the engine covers was a simple take it off get them powder coated and screw back on... Not knowing the rb25 covers are different to the rb 26 ones i got done on my gtr
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
