Yeh its probably the same as your in terms of response but definitely there is a top end. It's just kept pulling on top end.
Yeah true, -9's give you good top end with the response of the -7's.
Your engine looks nice and clean as with Mine's Purple colour.
Nice bay callan, love that manifold and turbo setup. Who made the manifold? U though about putting the washer bottle in front of the fuse box?
Just relocate it to the boot like mine :P When you break heavily the transition spurts water out the sprayers
This catch can set up, do you have anything else running to it that i cant see? or are the two top pipes it? it can be done this way because u have a filter to the atmosphere correct?
Anyone
This was yesterday, metallic silver goes down first then the translucent candy apple over the top. Obviously it gets darker the more you apply it.
hot mate!
are you a spray painter by trade??
Also rb25 and 26 coil covers are they all plastic??
rajab damn!
Not a massive job to get the 26 covers on bud. I had them on my 25 and loved it!
Main issue is the PCV as on the 26 covers, there's nowere to plumb it. I deleted my PCV so was a non-issue for me. Other than that, pretty straight forward :)
thanks mate... i just have a long list to do to finish it before Aug. was hoping tidying up the engine covers was a simple take it off get them powder coated and screw back on... Not knowing the rb25 covers are different to the rb 26 ones i got done on my gtr
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
