Yeh its probably the same as your in terms of response but definitely there is a top end. It's just kept pulling on top end.
Yeah true, -9's give you good top end with the response of the -7's.
Your engine looks nice and clean as with Mine's Purple colour.
Nice bay callan, love that manifold and turbo setup. Who made the manifold? U though about putting the washer bottle in front of the fuse box?
Just relocate it to the boot like mine :P When you break heavily the transition spurts water out the sprayers
This catch can set up, do you have anything else running to it that i cant see? or are the two top pipes it? it can be done this way because u have a filter to the atmosphere correct?
Anyone
This was yesterday, metallic silver goes down first then the translucent candy apple over the top. Obviously it gets darker the more you apply it.
hot mate!
are you a spray painter by trade??
Also rb25 and 26 coil covers are they all plastic??
rajab damn!
Not a massive job to get the 26 covers on bud. I had them on my 25 and loved it!
Main issue is the PCV as on the 26 covers, there's nowere to plumb it. I deleted my PCV so was a non-issue for me. Other than that, pretty straight forward :)
thanks mate... i just have a long list to do to finish it before Aug. was hoping tidying up the engine covers was a simple take it off get them powder coated and screw back on... Not knowing the rb25 covers are different to the rb 26 ones i got done on my gtr
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
