Yeh its probably the same as your in terms of response but definitely there is a top end. It's just kept pulling on top end.
Yeah true, -9's give you good top end with the response of the -7's.
Your engine looks nice and clean as with Mine's Purple colour.
Nice bay callan, love that manifold and turbo setup. Who made the manifold? U though about putting the washer bottle in front of the fuse box?
Just relocate it to the boot like mine :P When you break heavily the transition spurts water out the sprayers
This catch can set up, do you have anything else running to it that i cant see? or are the two top pipes it? it can be done this way because u have a filter to the atmosphere correct?
Anyone
This was yesterday, metallic silver goes down first then the translucent candy apple over the top. Obviously it gets darker the more you apply it.
hot mate!
are you a spray painter by trade??
Also rb25 and 26 coil covers are they all plastic??
rajab damn!
Not a massive job to get the 26 covers on bud. I had them on my 25 and loved it!
Main issue is the PCV as on the 26 covers, there's nowere to plumb it. I deleted my PCV so was a non-issue for me. Other than that, pretty straight forward :)
thanks mate... i just have a long list to do to finish it before Aug. was hoping tidying up the engine covers was a simple take it off get them powder coated and screw back on... Not knowing the rb25 covers are different to the rb 26 ones i got done on my gtr
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
