Hello all,
I have an Apexi Djetro (in before the cries of get a Haltec/Motec/Paltronic :)) on a RB26 and have been monitoring the Air Temp for a while via the hand controller.
As the standard RB ran AFM do they also have an Air Temp sensors? Or is this been added when the Apexi was fitted?
I think it may be this sensor in the front of the plenum?
I have noticed that the Air Temp does not vary wildly it stays around 45 deg when moving along. When standing it reaches 50 deg and then take 10 mins to creep back down to 45 or so. If the ambient changes 15 deg then there is no effect still 45 deg. It has a largish HKS intercooler as well as a couple of R34 N1's running 15psi so they are working hardish with all standard 32GTR piping and plenum in place.
This leads me to a few posibilities I am hoping someone can answer;
1) The Air Temp sensor installation is wrong and I am measuring plenum temperature? I need to correct this with either a different sensor or different installation?
2) The Air Temp sensor installation is right and the air temps recorded are correct? Perhaps then the RB is a candidate for a phenolic spacer between plenum and head?
I am a newbie with these engines.
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/
The airtemp sensor on the GTR plenum is standard.
The issue with it is the sensor gets heatsoaked from being directly mounted to the engine via the plenum.
Best to move it to either the cold side of the intercooler core or the cooler piping after the cooler to get accurate results
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6581122
Only a couple of Nissan engines of that vintage even use IAT sensors. That's pretty much the SR20 and the RB26. The rest could have benefited from them to provide better ignition timing adjustment with temperature, which would have provided better power in cold weather (or more to the point, they could have had less conservative ignition timing and still been safe when the IAT went hot). But because they all did run AFMs, they didn't need to measure IAT in order to calculate engine load, so they cheaped out on most engines.
I strongly suspect that the IAT sensor on RB26s does little more than nothing at all. There is precious little difference between an RB20 ECU and an RB26 ECU, and precious little difference in the way the calculations are done inside. Add the fact that the IAT sensor tends to stabilise at the plenum alloy temperature, and, well, you can see what I mean.
cheers
--edit -- correction. I accidentally typed RB20 in the 2nd sentence when I meant RB26.
Edited by GTSBoy
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6581205
Agree, don't think it does too much until engine temp gets high.
Stock Datalogit numbers I think?
IGN V's IAT shows 0 correction at 50 degrees down to -5 correction at 70 degrees.
INJ V's IAT shows 100% at 40 degrees, 112% at 70 degrees and 120% at 100 degrees.
And the probe is always heat soaked, never seen mine less than 50 when running which is in the vicinity of the zero and 100% spots.
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6581241
That stock sensor is really slow, inb4 haltec/motec/paltronic well... those computers can all be fitted with any modern sensor which respond much faster. So if you relocate this sensor to a less heat soaked position will it be fast enough to tune with?
Edited by linkems
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6581254
Thanks for the responses so far... a wealth of knowledge.
Unless I am missing something, there is no accessable trim tables for air temp correction via the hand controller. I assume they are embedded into the algorthm for final ignition and final fuel pulse within the unit and setup from Apexi?
Does simply moving the standard sensor make the whole system run better (i.e. correct fuel/ignition for a given air temp?).
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6581281
If memory serves me correctly in the late 80s era competition teams were finding that prolonged use off high speed and boost were causing lean outs which could damage pistons etc . I think it was Murray Coote that burnt a Familiar rally engine on some event that included long stages of full speed full load running . You would expect that everything could become heat soaked particularly in hot weather and a slow reacting temperature probe could make a difference . Its hard to imagine it doing much in a road car here driven at legal speeds .
A .
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6582734
A .
Looking at my other car ecu calibration... the fuel multiplier for two different air temp breakpoints 40deg to 20deg are 1 : 1.023.... or in other words 2.3% difference in fuel - lets say we aimed for 12:1 at a particular point in the map then 2.3% difference is 12.27:1 - I know it may not look like much difference but it is.
Looks like datalogit is the go - and now to find an Air Temp sensor!
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6582865
the air temp sensor and water temp sensor are the same part number, its the same part and you can use either
leave the sensor where it is and leave the ecu do its job - back out timing when intake temp is excessive
dont forget you are measuring air after the compressor wheels and after the intercooler so 45deg is pretty good
imagine the air temp at the compressor wheel outlets? its probably double that so 45deg is fine
there is nothing wrong and nothing to fix. dont move the sensor
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6583757
it works perfectly well, there are good trim tables for fuel and air via AIT too... there is a very good reason Nissan used slow reaction sensors.
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6586600
Hi guys,
After stumbling across this thread I remembered to post up an rb26 air temp sensor upgrade for the power fc I did a while back.
Here's the link: http://www.skylinesaustralia.com/forums/topic/412248-rb26-air-temp-sensor-upgrade-for-power-fc/
Hope it helps some people out,
Dave.
https://www.sau.com.au/forums/topic/411652-rb26-air-temp/#findComment-6594329
  • 11 months later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
