Hi all,
First post here, have been a skyline owner for some time. I'm driving a bog stock R33 GTST S1 (1994) with approx 170xxx km's on the clock. During some routine maintenance (I'm a mechanic by trade) I've discovered oil in my intake, from which I deduce my turbo is on the way out. I doubt it has been off the car since production, so it's no real surprise it's on the way out.
Anyway, I have no real desire to chase big power out of the car (it's my daily driver and don't want to send my fuel costs through the roof) so I'm simply thinking of replacing the turbo with another stock turbo after getting it rebuilt. However, if I can, I'll stick another turbo onto the stock manifold and just keep the stock wastegate and run standard boost through it so I don't have to modify the stock computer and injectors.
So! The question I'm asking is, can anyone put me onto a brand/make of turbo that I can simply bolt onto the existing manifold/dump pipe? Otherwise, I'll just chase down another stock turbo and rebuild it.
Thanks guys.
(p.s, if there is another thread with this information, put me in that direction and I'll delete this one)
https://www.sau.com.au/forums/topic/411705-r33-stock-turbo-upgrade/
  • Replies 60
Depends how much is in the intake mate. It's a common occourance as oil get out top of rocker covers and is fed back to inlet of turbo making it look bad.
Maybe check shaft play of turbo and if its minimal up/down and no end float then its prob fine and its just 170k worth of accumulation
Putting someone elses stock (ceramic) turbo on your car is taking a big risk, you don't know how it's been treated or how high boost they put through it. You're better off getting a turbo shop like Hypergear to highflow it and replace the ceramic wheel with metal ones.
Just get a stock one highflowed by Hypergear, you can run it as the stock turbo if you want, or if you want to tune and boost up will make good power with good response, plus it's not a random ceramic that's going to blow up, it's a rebuilt steel wheel turbo, definite win.
Bw33zy, if your looking at getting rid of your old turbo soon then I'll take it and.get it high flowed. Looking around at prices of rebuilt OEM turbos so we'll see how that goes.
Okay sweet, well Im only just down on the central coast. I am looking to make around 250-270kw so will be possibly getting a hypergear turbo, nistune and supprting mods
Another related question... can you just buy a new turbo with a t3 flange and bolt it on using the same actuator etc?
You could, but those ling long turbos off eBay are junk. Better off just getting an used high flow OEM turbo that is in decide nick or just send your turbo to hypergear and get it rebuilt for peanuts
If u do get a highflowed turbo as the boys are suggesting the ecu will need to be upgraded,
So it all depends on what ur plans are for the car on whether u should upgrade the turbo and ecu etc.
As was said already the oil may be from the rocker cover breathers rather than the turbo seals themselves.
I recommend cleaning all the piping and installing a catch can in between the rocker cover breathers and the turbo intake pipe, this will stop nearly all of the oil buildup.
By all means tho if u wish to upgrade the turbo u should but within a few thousand km's theres a good chance the oil buildup will return to the intake
Would an ecu upgrade be needed if I'm running.stock boost (7psi)? I wouldnt have thought so...
Last r33 i had come in was running very poorly due to r+r with the highflow.
The r33 ecu's are very sensitive to airflow changes and get upset easily.
Not saying u deintely will need it but just be aware its possible,
But remember it may not need a new turbo just because of the oil in the intake pipe.
Another question... Anyone ever put a Garrett GT3582R turbo on their RB25? I.e do they bolt up to the stock dump pipe? Can get ahold of one for around the same price as a highflow on my stock turbo.
lagggggggggggggggggggggggggggggg monster, and from other cars I've seen you will need a spacer plate, new lines and a 5x bolt dump to down pipe, not to mention the intake pipe will need to be modded or replaced
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
