Hi all,
First post here, have been a skyline owner for some time. I'm driving a bog stock R33 GTST S1 (1994) with approx 170xxx km's on the clock. During some routine maintenance (I'm a mechanic by trade) I've discovered oil in my intake, from which I deduce my turbo is on the way out. I doubt it has been off the car since production, so it's no real surprise it's on the way out.
Anyway, I have no real desire to chase big power out of the car (it's my daily driver and don't want to send my fuel costs through the roof) so I'm simply thinking of replacing the turbo with another stock turbo after getting it rebuilt. However, if I can, I'll stick another turbo onto the stock manifold and just keep the stock wastegate and run standard boost through it so I don't have to modify the stock computer and injectors.
So! The question I'm asking is, can anyone put me onto a brand/make of turbo that I can simply bolt onto the existing manifold/dump pipe? Otherwise, I'll just chase down another stock turbo and rebuild it.
Thanks guys.
(p.s, if there is another thread with this information, put me in that direction and I'll delete this one)
https://www.sau.com.au/forums/topic/411705-r33-stock-turbo-upgrade/
  • Replies 60
Depends how much is in the intake mate. It's a common occourance as oil get out top of rocker covers and is fed back to inlet of turbo making it look bad.
Maybe check shaft play of turbo and if its minimal up/down and no end float then its prob fine and its just 170k worth of accumulation
Putting someone elses stock (ceramic) turbo on your car is taking a big risk, you don't know how it's been treated or how high boost they put through it. You're better off getting a turbo shop like Hypergear to highflow it and replace the ceramic wheel with metal ones.
Just get a stock one highflowed by Hypergear, you can run it as the stock turbo if you want, or if you want to tune and boost up will make good power with good response, plus it's not a random ceramic that's going to blow up, it's a rebuilt steel wheel turbo, definite win.
Bw33zy, if your looking at getting rid of your old turbo soon then I'll take it and.get it high flowed. Looking around at prices of rebuilt OEM turbos so we'll see how that goes.
Okay sweet, well Im only just down on the central coast. I am looking to make around 250-270kw so will be possibly getting a hypergear turbo, nistune and supprting mods
Another related question... can you just buy a new turbo with a t3 flange and bolt it on using the same actuator etc?
You could, but those ling long turbos off eBay are junk. Better off just getting an used high flow OEM turbo that is in decide nick or just send your turbo to hypergear and get it rebuilt for peanuts
If u do get a highflowed turbo as the boys are suggesting the ecu will need to be upgraded,
So it all depends on what ur plans are for the car on whether u should upgrade the turbo and ecu etc.
As was said already the oil may be from the rocker cover breathers rather than the turbo seals themselves.
I recommend cleaning all the piping and installing a catch can in between the rocker cover breathers and the turbo intake pipe, this will stop nearly all of the oil buildup.
By all means tho if u wish to upgrade the turbo u should but within a few thousand km's theres a good chance the oil buildup will return to the intake
Would an ecu upgrade be needed if I'm running.stock boost (7psi)? I wouldnt have thought so...
Last r33 i had come in was running very poorly due to r+r with the highflow.
The r33 ecu's are very sensitive to airflow changes and get upset easily.
Not saying u deintely will need it but just be aware its possible,
But remember it may not need a new turbo just because of the oil in the intake pipe.
Another question... Anyone ever put a Garrett GT3582R turbo on their RB25? I.e do they bolt up to the stock dump pipe? Can get ahold of one for around the same price as a highflow on my stock turbo.
lagggggggggggggggggggggggggggggg monster, and from other cars I've seen you will need a spacer plate, new lines and a 5x bolt dump to down pipe, not to mention the intake pipe will need to be modded or replaced
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
    • You haven't driven many modern cars then have you? Most of them have sfa steering feel with their stupid electric bullshit steering systems.
