hey guys sent my car to mercury the other day to get a new fuel pump and nistune fitted and dyno tuned and only maid 156rwkw wanting at least 200rwkw any ideas?
car is pretty much stock except for
rb20det
rb25hiflowd turbo 12psi
255lph walbro f pump
fmic
3inch exhaust
pod
nistune ecu
stock injectors
stock afm
have a new 2 core ally rad and fuel pressure reg sitting at home to be fitted.
https://www.sau.com.au/forums/topic/414349-making-200rwkw-on-my-r32-rb20det/
injectors will be a good start, also ..nistune on a stock afm??? where is the Z32
also i have gtr coilpacks cheap to go with the injectors you need
Edited by GH05T
Z32? i think he's a bit off that.. hope you enjoyed the service... i prefer to actually talk to the person working on my car.. what did they have to say about the result?
Edited by SliverS2
didnt really say anything to me was a bit unhappy with it takeing over a week to get my car back but other then that i think they did ok. definatly will be fitting a z32 now thanks for the comments. any body know some not so pricey injectors to fit or for sale?
so you live around brissy?
Id be seriously thinking larger injectors and getting on the Eflex, it should help you alot in getting to 200kw with 18psi wound up..
I highly recommend you see Gavin Woods, cant speak highly enough of his work, your just as important as the guy with the 35GTR there.
You need to wind up the boost, my old hr31 made about 150rwkw on 14psi with a vg30 and exhaust but stock everything else. My 32 made 230+ but was running about 20psi.
I think the limit of stock injectors/afm is about 180rwkw on a rb20, so I would upgrade them first and get a re-tune, I think you will have to run atleast 18psi or so to get 200rwkw.
Edited by eightsixboy
so ive bought a z32 afm and denso 550cc will fit and tune in the next week or 2 and post a dyno. anything positive to say about denso injectors?
Have to change the plug, and when you want more power later you will wish you had of gone with GTR injectors.
    • Yes, I know🙄 but the sequential is not in my budget... don't want to reduce power neither, so looks like I'm stuck in the rabbit hole🤣
    • You’ll be very upset when you bust that too not to mention the gearing totally sucks. Don’t do it.
    • Is the panel filter one that is oiled? Have you ever cleaned or touched the AFM?
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
