Vettel is cleanng up his new rubber latex bondage suit and rubbing his hands and peanut sack and loving the fact he has another aussie to ram his 3inch knob into.
Big mistake for Dan. He is now the new official Barrichello.
Would much rather have seen Kimi there as he would have floored the little top bloke vetstool.
Off to Japan F1 next month. Will be boring as hell but I only go for the beer and Japanese candy.
So many writing off Dan before he has even lined up for a single practice session in the same car on the same weekend. I am not convinced it has been done purely because the expectation is that he will be a lap dog.
I think he has real pace...if RBR wanted to make their lives easy they would have canned Webber 2 years ago and put in any number of drivers like Di Resta, Hulkm an STR Jr etc. Webber has tried to give as good as he has taken and the team has hardly been harmonious whilst he and Seb have been battling.
I think its too presumptious to think that RBR want a lap dog and No.2 by definition. If Dan cant keep pace then he will be a No. 2 by default not by design. The other big reason why I think they need to put someone who will put it up Vettel is that by the end of his cotnract he will have been there 7 years! I think he will be looking for a change/challenge (provided the other team is competitive like mercedes or Ferrari) if he gets bored at RBR. And a young guy beating him will keep him interested and motivated.
Kimi, based on his behaviour at Ferrari doesnt always stay all that motivated when things are not going to plan
Depends on how much Tool can dictate terms to RBR doesnt it? Hoping Dan is like Webber in respect to not putting up with sh!t from anyone. Hoping he is not like him in terms of being able to get a car off the line.
Fingers crossed it goes well. Because other than some young bloke by the name of Brabham I cant think of where the next Orstraylian GP driver would come from.
it looks like he's focusing on indy.
for now anyway.
I'm not writing Dan off before he's started, but the facts are these:
Dan is not outscoring his current team mate. Not last year, and again this year. I don't think the three, soon to be four time WDC will be terribly worried in terms of the championship.
Dan appears to be a good qualifier. Problem is, Webber was also regarded as a very good qualifier... I wouldn't rate Dan as better than Webber in that regard. Maybe he'll prove that wrong, but I don't think so.
Webber is also a very good racer. I would definitely rate Webber's racecraft and race pace as significantly better than Dan's.
Dan does have one thing on his side, and that's the potential to improve.
Edited by hrd-hr30
Roy I'm knocking Dans ability but with Dietrich and Helmet head at the reigns and a German World Champ then Dan needs to learn how to say woof !.
Hope it's a different scenario but after 30 plus years of following F1 just looks the same old same old , just a different lap dog.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
