well at least you'll be able to hear Ted when they cut to him in pit lane
New V6 engines:
1 Pro
257 Cons
:P
But seriously...... they just don't have the that wail that the V8s had. Hopefully they sound better in real life
+1 for wanting Maldonado to leave Williams. They arent going to get any more sponsership by having a driver who is hopeless. They need a talented driver to impress the sponsers and bring more money to the team. Bottas was absoloutly outshining Maldonado at the start of the year. Not sure what happened there
I can't stand the V8 engines they currently have. Well.. not quite.. I'll tolerate them but they don't do much for me.
The V10's on the other hand.. they gave me an eargasm. Never saw a race with V12's but I would probably cream myself.
Turbo + wastegate should sound good.
Correct, on next years engines there are two Motor/Generator Units (MGU). These MGU's are the primary KERS now called MGU-K, and the secondary ERS called MGU-H, the MGU-H is designed to recover lost energy from the exhaust heat (hence the -H in the name) by driving a generator unit connected to the turbine shaft. Depending on how much energy is recovered from the exhaust heat, the turbo's airflow will be modulated in accordance to the engines requirements, this motor will also be used to drive the turbine at low exhaust gas velocities, thereby removing any inherent throttle lag with the system.
  • Like 1
The grandson of Australian motorsport great Sir Jack Brabham has secured himself a drive in the support category for the IndyCar championship in the United States.
Matthew Brabham was confirmed on Sunday as the pilot of the Andretti Autosport entry for next year's Indy Lights 2014, following his dominant win in this year's Pro Mazda Championship.
Brabham earned the right to move up to the Indy Lights championship after winning the Pro Mazda title in emphatic style, claiming 13 race wins from 16 starts.
It means the 19-year-old is just one step away from joining compatriots Will Power and Ryan Briscoe in America's premier open-wheel motorsports championship.
Advertisement
"I'm really excited to be moving into Indy Lights next year," Brabham said.
"I remember seeing the Indy Lights cars for the first time in St Petersburg when I was racing USF2000 there last year. I was blown away by how quick they were and how cool they sounded.
"It's going to be a fun year, and I'm very pleased to be on board with Andretti Autosport for a second year."
this is what i cbf writing. :)
this is why I love tech
and it will eventually filter down to us consumers
    • We have a huge update coming in the next few months, version 5 of Invision will be released. I'm holding off any changes until after this change as I'm not sure what features will be removed or introduced.
    • Yeah, plenty of air flow, there is a dedicated path that feeds the air in to the OEM intake tube behind the bumper As for a "tangible effect", maybe, but getting the pod/intake air out of the hot engine bay is worth it psychologically to me, even if it gives no performance difference, so the tangible effect in my Lizard brain saysss yessss  In the end, to me a tangible effect isn't always about performance, sometimes it a sound or a look, or even a...... feeling  Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga Ooga-Chaka Ooga-Ooga
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
