  • Replies 73
Mine is a White 96 R33 GTR V-Spec. Got it from compliance about 2 months ago now and am loving it. Was stock from compliance, have since added:
18x9.5" BBS LM with 265/35 Yokohama ES100s
Reconditioned APEXi T-max coilovers with king springs (FR 400lbs, R 225lbs)
Cusco Caster rod
Cusco rear camber arm
Whiteline Front camber kit and pineapples
DBA slotted 4000 series rotors FR & R
Came with dual APEXi dual chamber BOVs but will probably remove those in favour of a set of stockies.
Time to liberate some HP!
black 92 r32,trust tdo5  turbos,18 x 9.5 racing harts , here is a pic courtesy of merli
You will give me your wheels (waves hand, Jedi style)
awesome.
white 1992 r32 gtr but seems to have all the specs of the 1994 model (pull type clutch, electronic hicas pump in rear of car instead of hydraulic in engine bay etc
Hey Amaru, what does the pump look like in the engine bay / electronic Hicas pump in the rear? What does mine have?
I've got a White R33 GTR which was stock when I got it. (and basically still is) I've added a set of Nismo Clusters and centre gauges and I've got a Power FC ordered (hopefully I'll have it by Xmas) and a set of TE37's which hopefully I'll get in a few weeks.
as my name implies i can only dream about owning a GTR let alone a gts-t at the moment. i've only been for a drive in one slightly modified gts-t and the grin didn't leave my face for days.........buying my first skyline after months or years of slaving, that expression will be priceless.
I just sold my modded 93 GTST Type M. I lost money big time but I have the goal in sight, a 1989 GTR from Japan. still searching at the moment. have missd out on 3 so far. hope to find one this week.
but then its a damn long wait. I'm driving a 1979 Dato wagon at the moment.
I work damn hard for what I have and just hope that no one ever says you dont deserve it.
Have you ever had someone say to you or heard them say you don't deserve that car?
just interested thats all. I have seen some nice cars with wreckless drivers and i have thought that.
cheer
mark
Midnight Purple 95 Vspec
2530's
HKS FMIC
HKS Dumps
OS Giken Twin Plate
Sard 700cc Injectors
PFC + HC + Boost kit
HKS Cam gears
Full zorst
Z32 afm's
K&N Pods
Nismo Fuel Pump
Nismo Regulator
Cusco Catch Can
18" Impul Hoshino Racing rims
Defi Gauges
big stereo
etc etc.
315kw at all 4 wheels on 1.3bar.
Cheers
Brett
Mines a late model R32 GT-R (June 94 to be precise). White, with nismo sideskirts and nismo lower bootlid lip.
HKS suspension (very tough ride)
3 inch exhaust from cat back
17inch X 9 AVS wheels, Yokohama Grand Prix 255/40
Apexi Air (pod) Filters
Blitz Turbo Timer
Pivot Speed meter
HKS Cam Gears
Chip Torque Chip
Dyno: Max Power 233rwk @ 13psi
Quarter Mile: 12.84 @ 105.66mph
Drive it everyday and loving it!
I got a silver 1994 R32 GTR, its got ..
Tein type flex coil overs
Apexi pod filters
HKS front pipes
Trust cat back
DBA 4000 front brakes
WORK Termist 18x9.5 wheels
Rebuilt Standard turbo's with steel wheels
Apexi Power FC
HKS Cam gears
Cusco oil catch can
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
