The last of my adjustable arms showed up today,I went for the just jap front upper control arms.
I will get an alignment once i fit them all i'm thinking of going neg 1.5 degrees front camber and positive 7 degrees castor and rear neg 1 degree camber
I think that will be good enough to run on track and not increase Tyre wear too much on the street.
  • 1 month later...
My 356mm 8pot d2 brake kit from the group buy got delivered this week, for a big brake kit they are surprisingly light and are very well made.
and for the rear i went for dba 4000 series rotors with the QFM A1rm pads and gktech braided lines.
I finally had a bit of time on friday arvo and got to fitting it all.
A few other things were delivered aswell this week. it felt like Christmas with all the boxes of parts building up.
i got a kaaz 1.5way diff which will be a lot better then my standard diff which has opened up. I just need to find somewhere that can install in any housing for me. if anyone knows someone around the newcastle, maitland area who the would recommend let me know.
Gktech adjustable rear traction arms which i will helpfully put in soon with the rest of my adjustable arms when i get some time away from work and tafe again.
yeah it should turn out pretty fun, hopefully it will anyway
just a small update i purchased a hi octane racing pod filter enclosure hopefully this will keep some of the heat out of the intake.
i booked in for a track day at wakefield this thursday so i got stuck into fitting the rest of my parts and changed all the fluids.
i put in all my adjustable suspension arms
and the brake master cylinder stopper
Didn't come say hi but you were out with my other half at the track
Was weird two skylines that were similar didn't know which to watch as they sort of look the same from a distance
yeah my mates who were in the other sessions took photos of her going around thinking it was me. she was so much faster then me
I was the one who spent most of my time off the track though. i found out i have more balls then skill haha
yeah its had pretty well all the basics done and its where i want it for now just need new tires as they were letting me down and i found out after the track day they were made 10 05 so well past there use by date.
So its time for some nitto nt05's before i head to the track next.
Nice build thread :)
Any plan to put bigger calipers on the rear?
Any other suspension work that you're going to do?
No plan to go any bigger as of yet. i will have to really put the to the test next time i hit the track with better tires but i did find the fronts wanted to lock up more so then the rear.
i had to keep swapping wheels from front to back so i could wear the flat spots out.
Not anything else i have planned really for it suspension wise. Unless you or anyone else has some suggestions i could look into
I like what you've done with your build. It's similar to the path I'm following, getting the car as reliable as possible, will then look at handling and then power last!
Yeah i reckon its the best way to go the more reliable it is the more chance you get to enjoy it
Hey mate, nice build up. No expense spared on your parts hey haha, looks the goods on the 34 wheels! Im also from maitland, cant say ive ever seen your car getting about tho.
Thanks mate i really like the look of them aswell. I don't drive it around that much im trying to get it out more often though
  • 6 months later...
So not much has been happening with the car lately with trying to save to get to Europe at the end of the year.
but i managed to get enough money together to get some new tyres.
i wanted something that didnt wear to fast on the street and still go sorta alright on the track so
i got the nitto nt05 in a 245/40
Awesome man :) Apparently Pete isn't working up at Bridgestone at Greenhills anymore, so no more awesome wheel alignments from him. :(
Really fark I was gunna ring up tommorrow and book in.
Where has he gone too?
I have those tie rods that have being sitting in my shed for ages im gunna put in this weekend
If you wanna come round this friday arvo or saturday.
  • 5 weeks later...
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
