:O:banana: lol
Where did you source it?
I got it from Revolution Racegear at kotara. He has a few different seats set up in the shop and in a few of the cars that are kept there that you can try out.
I love my Pro 2000's but damn they're a pain to get in and out of!
It was a bit of a fun novelty at first getting in an out but yeah it does be come a pain.
Thanks Mate! Appreciate it... Will look them up!
  • 1 month later...
So with E85 becoming more available now and with having 2 servos within 5minutes from my place now selling it. i thought i might give it a go and start running it.
Some of the parts i have started collecting for it.
f0ff8fac-bf94-4d59-a892-b039ce5cfa5a_zps
Walbro 450 E85 fuel pump and Xspurt 1000cc injectors.
a85f35af-da8d-4c00-ba76-1388c3df4072_zps
One of scottynm35's intake
Fuel rail kit from scotty with adaptors/spacers so i can run the top feed injectors.
Im still tossing up on what ecu to use so i can run a flex tune as i don't want to run dual maps on the powerfc, I'm leaning towards the Adaptronic select plug in.
Probably comes down to the issues of budget and tuner preference which way you go with ECU.
What do you think of the steering wheel and boss setup? Did it change the length of reach to the wheel? Presuming slightly smaller diameter is there any noticeable difference in steering effort? And any obvious flex in the wheel if you apply in/out pressure to the rim?
Overall im pretty happy with it the only real downside is that i cant fully see the top of the speedo and tacho as the top of the wheel is just in the way but that will be different from person to person depending on there height and seat height as well.
The wheel is closer to you so less of a reach to it. Yeah it is slightly smaller diameter i think its 350mm but i haven't noticed any difference in steering effort. There is a bit of flex in the wheel if you go pushing and pulling on it but i haven't noticed it while driving though.
  • 1 year later...
Its been awhile since i have updated this i had other things get in the way but i have finally got my priorities right and can continue with the build.
i have been collecting more parts lately so it should move quite quickly from her on in.
So i got an NPC cushioned button clutch which will handle the abuse i throw at it.
d00a4b93-d449-4522-8d8e-d67d2f45ae66_zps
Im not yet i will be soon i bought bought an adaptronic select plugin ecu and flex fuel sensor a few months back and just ordered my new turbo on the weekend.
I went for the hypergear ATR43SAT with the roller bearing CHRA, So i will start running it in the next couple of months when i have it all on and go in for the tune.
Yeah thats good to know i havnt heard of anyone having any troubles with them.
    • Just wanted to unearth this and post my baby with the new front ❤️😝 Took her to my wedding rehearsal today. Next up is getting wide skirts (after wedding)
    • Yea, that is what I was getting at in my ramblings too. The nismo one actually is a 1.5 way and a 1 way. They don't do a *2* way because a true *2* way would have equal ramp angles. Or is that a true 1.5 way? Realistically I think a "1.5 way" does not actually exist. A diff can either lock in two directions or one. It also doesn't help that a LOT of people in Australia speak about 1.5 way diffs are referring to their 1 way diff.
    • Well, the trouble with that ^^ is: The configuration shown is absolutely a 1-way, not a 1.5-way. There is no way that a 1.5-way can be said to offer LSD action only on acceleration. If Nismo cannot get that right, then it is impossible to believe their documentation. That ^ is not a 1.5 way setup. That is a 1-way.   And so now I have allowed all doubts to flourish and have gone back to look at the MotoIQ video. I originally made the mistake of believing him when he said "this is a 1.5-way" at the ~6:10 mark. Because what he did was take the gear assembly out of the 2-way opening and just rotate it one place to the left to drop it into the 1-way opening. When he dropped it in there, the cam was "backwards" compared to the correct orientation shown in all other photos of that config. The flat shold have been facing the 1° ramp side of the opening, not the 55° ramp side. And I thought, "gee that's cute", but I was concerned at the time, when he put the other ring back on, that the gap between the rings looked like it was wider then in the 2-way config. And then I said a lot of things in my long post on Tuesday that could only make sense if the guy from MotoIQ was correct about what he'd done. BUT... I have now done my homework. I grabbed a frame of the video with the 2-way config, and then grabbed another with the "1.5-way" config, snipped out the cam and opening of that frame and just pasted it direct on top of the 2-way config. I scaled it so that the triangular opening was almost exactly the same height in both. AND.... the gap between the plates is wider with the cam installed in the triangualr opening backwards. That is.... it cannot go together that way. There would be massive force on the plates all the time, if you could even reassemble it.  So, My statement on the matter? The Nismo diff is actually only a 2-way and 1-way. There is no 1.5-way option in it, regardless of what they say. Here's a photo of a real 1.5-way ramp opening from Cusco (along with the 1 way option). And the full set of 1 through 2 way options from their racing diff, which is not same-same as what we'd typically be using, but...the cams work the same. A little blurry, but it comes from this Cusco doc, which is quite helpful. AND.... Cusco do in fact do what I suggested would be sensible, which is to have rings that do 1 and 1.5, and 1.5 and 2. Separately.
    • Welcome Adam. Car looks great!
    • "With a 1.5-WAY, the LSD is effective only during acceleration."
