  • 1 month later...
  • 1 month later...
  • 1 month later...
  • 1 month later...
WTB R33 standard rear springs. Wondering if anyone has a pair lying around they don't need... Happy to pay or swap for my current full set of Lovell springs. I carry my kids around these days and dont need sporty suspension anymore...
  • 1 month later...
  • 1 month later...
On ‎27‎/‎02‎/‎2017 at 1:10 PM, dorifticon said:
Need an r32 GTR transfer case in known good condition (removed from running car and/or no debris in the oil), if anyone here has one please hit me up ASAP
zero 4 one 5, 838, seven 90 is the best way
Andrew
Did you get one Andrew?
