So I could not get much done last weekend as I was doing a much needed service on my Ford Falcon POS (was the first time I ever done it but paid off really well :yes: ).
I did however managed to paint the exhaust heat shield after I sanded them
Just have one more exhaust to shield to clean (and probably sand as well) and paint
still waiting for more parts from Japan to arrive, once it is here I will of course post pics but then the car will go to Gavin Wood Autotech to be put together and run-in tune, which I can't wait to see :banana:
Edited by Ants
Surprise time!!!! Received this today :woot:
HPI Clutch line
Nismo big operating clutch cylinder
Nismo racing release fork pivot
I think you guys would have pretty much gathered that all the of the above is pretty much useless without this.....
Neeeezmo Twin Prate Crutch :P rated @ 640ps (I wonder if I should of got the competition spec instead :glare: )
Lastly a little something that may / may not go on the car
Cusco short antenna - carbon version (not even sure how this will fit the R32?)
Got a little more to come...peace :cool:
Well for me it kind of is.
Since my GTR has been off the road I have not been able to listen to the radio because my daily does not have a working radio or any music I can listen too (its an old car)
In addition to that when I installed my Sony DIN in the GTR I noticed how crappy the radio reception is (it's rather weak).
Anyways its not that important, rather more of a trivial item I guess.
I was more excited to get the clutch!
Edited by Ants
Nice clutch!
I wasn't going to buy anything else for my car till the re-build but now I'm tempted to buy a Nismo Slave Cylinder and Pivot Fork now.
Thanks! ;)
No worries mate.
Kind of cant wait to put that and everything else in the car, just been a bit hectic lately with family.
But all in all, is very good as we are expecting another little baby girl :turned:
Edited by Ants
Mount the aerial behind the grill between headlights somewhere, you don't need to see it for it to work :no:
Good idea Brett.
But for the moment will focus on putting the engine together first and get it tuned ;)
Edited by Ants
After seeing my good friend Robbie ($$slowmedown) going nuts with black wrinkle paint I thought I would do the same :woot: so :thanks: mate.
Radiator brackets without rubber grommet
Wrinkle painted
underside also done
also got to do the final exhausts heat shield all cleaned and sanded down
With F1 on and cyclonic winds this afternoon it was an achievement to get this painted outside but all done :miner:
Edited by Ants
Received this today
Brand new coolant overflow tank and new GENUINE N1 windscreen washer bottle - I will later show you guys know how to install this and remove the rear wiper + motor and how to blank the holes up properly on the rear windscreen ;)
Now this is going to be interest, because I accidentally used the wrong part number from my Nissan FAST program and got this instead of another item I wanted to get (also from N1 model)
Genuine N1 assembly manual climate control - I have know idea if this is going to connect to the existing plugs or not but I guess I will let you guys know soon enough.
Now that I have it this part, I might make it worth while and remove a/c from the car and save more weight :woot: or I will just sell it to someone if its too difficult - has anyone done this before???
Anyways, I am waiting for another parcel which unfortunately is being held up as it was purchased in Australia - it seems that things from Japan arrive faster compared to ordering and purchasing in Australia which I just can't seem to understand :rant:
Great build thread!
I personally like the look of the stock R32 GTR climate control unit.
Where are you buying your Nissan parts from? Just your local dealer or online somewhere?
Cheers
Thanks mate.
I have to agree with you, the digital climate control does look more modern. But I will see if I can get it to work and if so, I will then proceed to remove the A/c system on the car :miner:
The only crappy thing is that Nissan no longer make the N1 control assembly finisher (the surrounding plastic) so I will see if I can source one second-hand or just fabricate one from carbon :dry:
Don't even bother with local dealers....I have sourced majority of my parts directly from Perfect Run Japan of whom I have now established a very good relationship. They do a sensational job and are very fast at sourcing and delivering parts at much cheaper prices than local dealers and highly recommend them :thumbsup:
And yes I have previously used Nissan here on the Gold Coast and purchased brand new R32 GTR front fenders, front bumper and lower lip which was out of this world f@#king expensive and took like 8 weeks to get here because they had none in stock at Melbourne warehouse....learned my mistake very quickly I tell you.
Plus with the strength of our AUD it is just cheaper to buy directly from Japan even after P&H, duties taken into consideration.
Great stuff mate.
Cheers for the reply. I'm doing a similar build with mine and am replacing a few of the worn out factory items with new genuine so that information is really good to know.
I look forward to seeing how you go with it all.
Chris
Big day today.....
Firstly I installed the new coolant tank reservoir
the decrepit reservoir next to the brand new coolant reservoir tank
all installed :miner:
next up...
I reinstalled the exhaust heat shields with new bolts, nuts and washers
then....
after almost three years of being on jacks the car is finally back on terra firma
I am so happy to finally have it ready.... :sweat:
enjoy.....
next stop.....Gavin Wood Autotech :banana:
Nice build, love how meticulous you are when it comes to things. I waste more time painting and getting a nice finish on my car than i need to and make a half hour job take an hour or two. Its a disease.
By the way thanks for putting me onto perfect run. Wouldn't have known about them otherwise.
How would you rate their postage times? Are they easy transactions? Had any issues?
Their website makes it look easy to order things.
Cheers
Matt
Edited by Grimesy
Cheers
Matt
Perfect Run is awesome. They use EMS, best postal service I have ever used. Took 3 days fro the time of ordering for my HKS cam gear to arrive. Had a problem where I forgot to change my address before I placed the order, sent them an email and they were very good to deal with, sorted everything out no fuss, no delay.
Cheers
Matt
Yeah man I just spent the last our on perfect run website. I wouldnt of known about them otherwise either
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
