I've been told that all cars, in particular Japanese cars, overestimate your speed, so that the speed shown on your speedometer is actually off by a bit. I tested mine using a phone app called Ulysses Speedometer which uses GPS tracking to measure your speed exactly. I discovered that my speedometer is off by a ridiculously huge 8.3%. Which means when my speedo reads 100, I am actually only driving 91.7. And that to reach 110kmph which is the top speed on some highways, my speedo actually has to read 120kmph. I dislike having to estimate the speed I am driving at and never quite sure if I am now speeding or not, and am annoyed that I must be the frustrating person on the road driving unecessarily under the limit.
Have you guys measured the difference on your car? Is it similar to mine? Can it be adjusted?
Edited by puddlejumper
my old car had speed on the turbo timer which was usually about 2 kph less than the speedo at about 100km. the timer was calibrated at 60kph from the speedo though...
Comparing speedo to satnav in other cars usually had about 2-3k difference also (but they weren't jap)
So i think usually a speedo is only a cpl k over actual speed.. things such as tire size and wear can have an affect on the precise accuracy...
As per above, unless you are running the stock tyre sizes (which almost no-one ever does - even on stockies), then you will affect your speedo's accuracy. My tyre width/profile is WAY off - my speedo is out by about 15%, but I compensate for it and normally use my GPS digital speedo instead of the oem cluster.
You will find all the V35's and M35 Stageas have this discrepancy, but the ecu gets a good speed signal and you can display this actual speed via the obd2 port. (it is much more accurate.)
I agree, it is very annoying and can cause frustration, 10k's out at 100 is a joke.
My V35 is fairly close. About 2% last time I checked with GPS. And I am running stock size tyres.
But our J31 maxima is out by about 8%. Again with stock size tyres.
My V35 Coupe seems to almost spot on - I've tested at 80 & 110 against the GPS in my phone, and the difference is no more than 1 - 2 kph. I've got 18s with stock rear tyres - 245/45R18.
I got 2km/h difference between the fronts and rears because of the tire sizes (width and profile) that came with the wheels, I'm not sure how much it is in relation to the speedometer. Use this tire size calculator (http://www.1010tires...ecalculator.asp) to help you choose the tires within the closest possible tolerances for your set of wheels. There may be other factors as well...
Edited by 81gSKy
Here's the results of a test I did a while ago. As per above, the Informeter (display from OBD2 data) is accurate, thus confirming Nissan deliberately engineered our cars to show the incorrect speed on the dash.
So, are we saying that the GPS is connected to the engine control (ie fuel)? and the traction control as well? What happens when the GPS loses a signal?
?? GPS is only used for Navi. If you don't have Navi, your car doesn't even have a GPS receiver. the ECU uses wheel speed sensors to determine vehicle speed (as well as using them for ABS, TC and VDC). If you are running stock size tyres, the ECU speed derived from these sensors is quite accurite.. however, the speedo doesn't display exactly what the ECU reads, the speedo almost always reads faster.
If you look at the graph above you will see it isn't 10% across the board.
I corrected the speedo on my J30 years ago, there was an adjustment on the back of the speedo cluster which adjusted a % of speed, however, the speedo was also out by an absolute figure, there was no adjustment for this, but fortunatly I was able to elongate the mounting holes where the speedo mechanism attached to the face, that allowed me to make an absolute adjustment and I was able to get the speedo to read accurite at 60, 80 and 100km/h.
I had a look at the back of the speedo cluster on the J31 Maxima, but there is no physical adjustment.
at least puddles speedo is out in the negative direction. years ago i found out the hard way that my car was showing 100 on the speedo but was actually doing 111 on the road... *flash*
You should've been able to contest that... Right?
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
