Lol. My last post got all jacked up. I'm trying to find part numbers in FAST. Does anyone have a N1 chassis code?<br /><br />Sent from my SC-03D<br /><br />
That'd be it. Chef bought it for me a couple of months back. Just waiting on that all important comp plate. Car is based in NSW unfortunately.
Hope to have it out at a drive sometime this year.
Well done! Nice car. Enjoy it when the plate comes through. They're superb!
Does yours have a driver's airbag?
Hi Guys
V Spec II
Chassis number: BNR32 311842
Just got my mine through Iron Chef.
Car currently has 34,000km and is 100% stock except for Nismo pipes coming off the turbo.
Hopefully the car will be here and on the road in around 2 months.
Hey Mate
How did this car set you back if you dont mind me asking, you can pm me if you like thanks, i been thinking of getting one put prices are all over the place....thanks
yours is an awesome example .......
Edited by AsM
Hi,
Prices do vary but the really nice ones cost a fair bit more. V Spec's appear to command around $10K more than a GT-R in similar condition/kms.
Here's one that went through recently;
http://prestigemotorsport.com.au/stock/show_car.php?id=875
Mine was more than this due to the lower kms and better interior. The one above has a couple of mods, turbo timer, exhaust etc which I was hoping to avoid.
Good luck and let us know how you get on. ]
Nice!
With full Nismo Body Kit too!
I was told, also being a Black colour V-Spec II, it adds more value to the car.
Either due to the popularity / demand or the numbers that were made of the car.
Nice!
That's debateable. If it is the case then it isn't the build numbers as there are other factory colours that are much rarer for VSPEC 1 &2.
Black is always popular though, so is the Gunmetal Grey as it is "The Original" R32 GTR colour.
Edited by RS4StagMan
Yeah, sure :)
I recently just spoke to a new owner of a Black V-Spec II and that's what he said...
Due to the popularity of people wanting a Black coloured one.
I get the impression that those N1/Nismo hood lips and boot spoilers are more trouble than they're worth - the steel structural inserts rust and 'blow' the surface. I kinda wished that mine had had them specified when it was delivered, but I'm glad it didn't now. The Nismo front bar though, that's different. I lurve the fact that mine has one ;)
I'm not a mad fan of the black though. Very hard to keep a black car looking clean, whereas my Gang Ray Metallic car can get really grotty and it still looks pretty good - until you get close!
Agreed. Black looks awesome when its well cared for and 100% clean. As soon as it rains or even gets dusty then its downhill from there.
I was very happy to get metallic grey.
  • 2 months later...
It took me long enough to get around to doing this.. But here we go:
  • Model of car V-Spec II, Built mid '94 somewhere
  • 'Chassis No' code BNR32310112
  • 'Model' code from the chassis plate
  • Photo of the blue chassis plate that is fixed to the car in the driver's side of the engine bay
  • Where the car is located Located in Bathurst
My theory (which is highly theoretical, as far as theories go) is that the car may have a history as a pace car or similar, it has marks which appear to be from a light bar on the roof, it had harnesses, braided lines, bonnet pins, castor rods, Nismo body braces, twin plate, master cylinder stopper, HKS boost controller, hard piping kit, Nismo clutch slave and nismo dash. Also still had ceramic turbos, stock suspension, speed limiter, all interior in good nick, no scratches on the front lip etc. I have tried to find some form of evidence to back this up, but have found nothing other than what was on the car.. Either way, it is a bit rough, with clear coat coming off, and the paint on the bonnet is like sandpaper, but I wanted to own a V-Spec II for 10 years before I bought it, and it will never be for sale..
Oh, and there might be another GTR in the family..
That's awesome iplen - it does sound like a pace car. It looks fierce.
I reckon I remember another one of your posts somewhere. Isn't the R33 your Mum's?
And yes, how did you go against that Holden?
I think I can post here too now.....
As of yesterday....
  • Model of car V-Spec II, Built Oct 94
  • 'Chassis No' code BNR32313245
Also sourced from the Iron Chef (I think i can blame Cherry Racer - they teased me with a picture of his car as one of their recent imports ;-)
Short details:
Silver
Stock
Single owner
17,300 kms (full documented service history)
Grade 5A at auction
Obviously still in Japan so here's the auction snap (already plastered in other part sof the forum - but just so happy right now ;-)
Cheers
The Baron
  • Like 2
    • ..this is the current state of that port. I appreciate the info help (and the link to the Earls thing @Duncan). Though going by that it seems like 1/4 then BSP'ing it and using a bush may work. I don't know where I'd be remote mounting the pressure sender... to... exactly. I assume the idea here is that any vibration is taken up by the semiflexible/flexible hose itself instead of it leveraging against the block directly. I want to believe a stronger, steel bush/adapter would work, but I don't know if that is engineeringly sound or just wishful thinking given the stupendous implications of a leak/failure in this spot. What are the real world risks of dissimilar metals here? It's a 6061 Aluminum block, and I'm talking brass or steel or SS adapters/things.
    • And if you have to drill the oil block, then just drill it for 1/4" and tap it BSP and get a 1/8 to 1/4 BSP bush. The Nissan sender will go straight in and the bush will suit the newly tapped hole. And it will be real strong, to boot.
    • No it doesn't. It just needs an ezy-out to pull that broken bit of alloy out of the hole and presto chango - it will be back to being a 1/8" hole tapped NPT. as per @MBS206 recco. That would be for making what you had in alloy, in steel. If you wanted to do just that instead of remote mounting like @Duncan and I have been pushing. A steel fitting would be unbreakable (compared to that tragically skinny little alloy adapter). But remote mounting would almost certainly be 10x better. Small engineering shops abound all over the place. A lathe and 10 minutes of time = 2x six packs.
    • Ahh. Well the block damage is a problem, you really need to run a tap or thread chaser through it to see if the threads can be saved, but any chips are likely to be bottom end bound which is bad. Earls seem to have what you need if you want to stick with mounting direct on the block: https://rceperformance.com.au/parts/earls-straight-adapter-1-8-npt-male-to-1-8-bspt-female.html, but as I said above I'd recommend remote mounting the sender
    • I'm not quite understanding or I'm missing steps here, (I appreciate people are trying to inform my brain but I am of the dumb, especially today) - All I want to do is mount the male BSPT of the OEM sender into the system somewhere without it snapping the adapter via vibration. The Nissan sender has a male 1/8 BSPT output. The block has a (very destroyed) 1/8 NPT input. I'm not really sure how a lathe assists with that, and also don't know anybody with a lathe, nor specifically what I would want to buy. I'm not really sure how adding additional adapters creates a better, more leak proof resilient seal here.
