Yeah but it doesn't stop people from putting them on, mine had a fake 33 Gtr badge on it when I bought it and I took it off and fitted a genuine 32 one
  • U need the genuine GTR badge on the rear, that looks like the larger r33 badge
Well spotted but I don't think it's a 33 badge. The ADM is actually slightly bigger.
Could someone else with a V-Spec 1 or 2 please post up what your badge looks like?
Thanks,
Bob.
Yep....... Mine must be fake then as yours is the same as my red ADM.
Oh well another one for the list.
Approx. A$71.50 - here - http://nissan.epc-data.com/skyline/bnr32/3891-rb26dett/body/990/84815MF/
If anyone needs one, make sure you get the correct colour code for your car, mines KLO.
Marco..... Yours wont be listed as I've only searched for Series 2 cars built after August 1991.
Your Jet Silver is slightly different to my Spark Silver.
Cheers,
Bob.
Why are the ADMs jet silver and JDMs spark silver? Your ADM is a different code to the red JDM right?
No....... Jet Silver Metallic was discontinued at the end of Series 1 cars in August 1991.Paint Code KG1
The shade changed slightly lighter in Spark Silver (some actually call it Sparkling Silver) which started with Series 2 cars in August 1991. Paint Code KL0
The list is posted here - http://www.skylineowners.com/forum/showthread.php?t=207531
The ADM and JDM Red is the same colour with the same colour code. The only thing that changed slightly was the name.
In Japan it was sometimes know as either Red Wine Metallic or Red Pearl Metallic. In Australia, the Dealer bulletin clearly lists is simply as Red Pearl Metallic. Paint Code AH3.
I hope that clears things up.
Bob.
Makes sense Bob, thanks.
Mine is July 91 and my brother also has a silver GTR (1 of 6 Scuderia edition) which was a low volume import and sold here as a new car...his is an 89 but his paint is slightly lighter than mine when it should be slightly darker, as per your above post
Marco....... Your brothers GT-R and your ADM should be the same colour.
It wasn't until AFTER August 1991 the lighter Spark Silver was introduced.
What does the paint code say on the firewall?
Bob.
Thanks,
Bob.
That's a R34 GTR badge.
Went for a very early drive this morning and FINALLY got some reasonable pics....
Cheers,
Bob.
Bob nice car mate.
Is your sliver car a genuine V-spec II?
Also, I have yet to confirm this however, I am under the impression that R32 V-spec model never actually came with a V-spec sticker is this accurate?
Yet to find out mate but his silver is definitely lighter and brighter when parked next to each other. Probably best way to describe is mine is more a browny silver and his is more bluey silver.
Bob nice car mate.
Yes.. Genuine V-Spec 11.
I checked out the numbers well before handing over the cash. It has been painted so no surprise the badge is wrong.
BTW.... V-Spec cars did have boot lid decals from the factory.
Cheers.. Bob.
Bob and Wruckie - gorgeous looking cars! Wruckie, don't change it - it's ace just as it is. Keep it the same spec as it was originally. It'll hold value better.
Is anyone able to help out gtr judd?
Hey guys I'm tryin to decipher my mate's chassis plate. Can you please help me on the end part.
So towards the end
X is Gtr
F is 5 speed
S is turbo intercooled
L is fog lamps (are these operated of the cluster?)
No number so V Spec 1
M is rear wiper less
Z is N1?
G what is this?
No worries, I would dig up my info but I'm busy getting ready for a knee reconstruction tomorrow so I'm a bit stuck for time.
I believe that Bob has a couple of decoder links. I reckon he might have provided them earlier in this thread. Gave a quick flick back through the pages.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
    • Can you also make sure the invoices on the box (And none exist in the boxes) are below our import duty limits... I jest, there's nothing I need to actually purchase and order in. (Unless you can find me a rear diff carrier, brand new, for stupidly cheap, that is for a Toyota Landcruiser, HZJ105R GXL, 2000 year model...)
