I am throwing out a westinghouse dishwasher on Monday morning. Perfect working order and white in colour. I have just changed to stainless. If anyone wants it let me know
Get my full license back in a few months which will mean I'll have another streeter, hopefully catch up with a few of you guys again on a friday night.
I'm trying to talk one of the Irish boys at work into buying your 180 lol
Oh no. speeding find, 6km over :( First one for me since 2000. Same road too!! (west tce)
My bad - must pay more attention to the cruising speed.
What would be good is a speed limiter that is adjustable. Press a button up or down to preset to a determined speed that the engine wont go over......
Sooo cant afford it, but you do the crime so do the time :/
Bad luck there Brendan - ironically I got my first fine since 1995 a few months back on a local connector road I drive every day.
But the answer is cruise control - and I use mine religiously.
  • Like 1
I had VDO speed alert in my R31, worked quite well, however you can buy GPS head units that have built in speed alarms - I got mine from China, $320 special...
-D
^^ E-go - we sent a Mitsi V6 to Brisbane a few months ago. Got a wooden pallet, used some thin steel bar and bits of 4x2 wood to bolt the motor to the pallet, then wrapped it in plastic (black wrapping plastic - bit like glad-wrap but thicker) & dropped it at the E-Go depot. Price was very reasonable, and it arrived with no problems. Paid a bit extra for insurance.
Im a wanted man these days Brad, will have to see what the go is
Whats the job we've bid for up there?
I might not get it if i need Electranet switching, ive been the only bastard to dodge that bullet and i actually want it haha
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
