Yes.
Tomei were my start point but I couldn't find a reference to an 86mm piston, only oversize ones.
Didnt look at ACL or Nitto (Not that the NItto list has an 86mm size anyway) because I didnt want to use them.
Have CP pistons currently and given the issues I have dont want to go back there either.
Edited by djr81
Despite all available evidence being to the contrary I am not a complete idiot. I understand cps reputation. None the less I would still like to establish who makes forged pistons in 86mms because from what I can see it is a much smaller number than for oversized pistons for obvious reasons.
I'm not sure who's insinuating you're an idiot but it's certainly not me! I'd love to know what went wrong though. I've got 2 RB's with forged CP's so keen to know what could potentially go wrong.
Are the slugs going in a brand new engine? The reason I ask is most of our 12-21 year old RB's are pretty much due for re-sizing by the time their due for new pistons.
Sorry for deflecting from your goal!
My quick Google search brought up-
Arias
Wossner (??)
HKS
CP
JE
ACL
Gong Chang (holy crap, the Chinese are on board the forgie train!!)
Apexi
Pretty good choice really..
I would also line to know what went wrong with CP pistons.
I believe that information may be more valuable that the current display of attitude. Particularly to us CP users who have put their hard earned into big builds.
Attitude? FFS.
I said I had engine issues.
I said I didn't want to use CP's again.
I did not say the cause of the issues were the CP pistons or that there was anything wrong with the brand.
Happy?
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
    • the top black section is bonded to the silver section with some form of rubber. I assume to isolated NVH from the box
