Hi all,
Not sure if this has been covered before or not properly (did search), I basically just want to know if stock 33 gtst brakes with decent pads/rotors/lines are good enough for light track days?
I don't want to upgrade to Brembo's or d2's/ksports if its not really required, Im not going to be diong alot of track work, maybe 2-3 track days a year at winton plus deca's.
I would love to upgrade rotors only to GTR and use the stock calipers but know one makes the adaptors besides uas ($350+).
Let me know what you guys think before I start buying rotors and pads.
Thanks.
https://www.sau.com.au/forums/topic/417146-potential-of-stock-33-gtst-brakes/
  • Replies 45
for light track days they are fine...Ive been punting around a few track days with 300kws still on the factory fitted discs from 93. With just some braided lines, better brake fluid and pads.If you can get some ducting in to help cool them would be good and aim for a softer compound pad that wont destroy your rotors and they will last longer than you think..
my times aren't killer but they are respectable and I can fly down the straights which is still awesome fun..just have to brake a bit earlier than the guys with good brakes ;)
A cheap upgrade like some RDA slotted rotors and some new pads will help a fair bit for the price.
It's about all I have and my brakes feel really good. Obviously not going to be stopping like a Formula 1 car, but still pretty damn good :)
They are absolutely fine. I ran stock brakes on my 33 gtst for about 3 years of track days. The trick is to run good tyres, plus I didn't have a lot of power. And a dot5 fluid like motul rbf600.
On the other hand, the d2 kit is very cheap and performs very well....keeping in mind it comes with pads, rotors and braided lines, and the rotors are 2 piece so cheaper to replace when that does come up
I was amazed how much difference putting on a well used set of 03Gs dunlops made to my stopping...:yes: even when cold they just dig in...
I think some simple air guides would help quite a lot. Coupled with a cross-over pad like DS2500 or A1RM pads. Next step would be HC+ pads, which can be driven on the street (weekend car).
GKTech have the R33 adapters to 324mm back on the drawing board. ;)
With decent tyres you won't have to wipe off so much speed for corner entry. The brakes are probably good enough for most Aussie tracks for R33 up to 250-260rwkw, with appropriate pads.
Edited by simpletool
If your std rotors are fine thickness wise then dont upgrade them. The std rotors are better than most aftermarket rotors you will throw on so dont waste your money. IF they are undersized then replace them with whatever generic rotor you can get cheaply.
THE BIGGEST change you will do to your brakes is the pad you run. Do you have ABS and do you like realy bitey pads or do you like needing a lot of pedal effort? Something up spec like Endless CCX will go a long way to giving you braking feel and bight you didnt think possible with std brakes, which when combined with good fluid makes a big difference.
If your lines are in good nic dont bother with braided lines as they are an expense you can live without. f youc an do all the labour yourself and get good braided lines cheaply then throw them on...but dont spend $500 on them through a workshop as whilst they are a good thing...that money is better spent elsewhere on the car...ie tyres
Thanks for the replies.
My car has ABS which while good for the street is prob not the best for the track, or so I've heard.
I need to measure my rotors, hopefully they can take machine and just replace the pads and lines, I would really like to use the 324mm rotors, just sucks theres no brackets for them yet to make it worth the $$$.
Has anyone heard of TRW pads? I saw a set on ebay, there only $130 or so and the guy said there almost as good as red stuff''s for light track work just half the price.
Could get 32mm rotors to fit, but then may as well just buy a big brake kit anyway
No, that's not the problem. The problem is the length of the caliper legs is different. If you put R33 calieprs onto the dogbones intended for R32/S15 calipers, then you need something like 340mm rotors.
intima pads are awesome for the money, actually prefer them over most of the others
Even better, bigger rotors :yes:
just buy direct from gktech online?
Yeah I just got them online, good service too answered all my questions
http://www.gktech.com/index.php/s13-s14-s15-r32-r33-braided-brake-lines-front-rear-set-intro-price.html
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
