1 hour ago, Dale FZ1 said:
The widened front and rear bodywork look great!!
Very interested to hear what the TTI box goes like.
Cheers for the feedback.
I have only had a a handful of laps and so far the box is nice to drive. I am still tuning my flatshift setup so there is a still a few timing issues but that has nothing to do wit the box. Being the sequential I have driven I have no commparrison butt he first thing i noticed is you have to put more effort into pulling the lever going up the gears. Going down is way nicer and easier than I thought it would be.
3 days before load up day the did not have an engine in it. With a few late nights we got the new engine in, onto the dyno and few loose ends fixed up. The next day it was loaded onto the trailer and then the truck for it's journey to Bathurst.
The truck leaves on Saturday and I leave on Tuesday.
This is a child hood dream coming true to be able to drive Bathurst in anger.
  • Like 1
1 hour ago, timmy_89 said:
What garage are you in? I'm helping pit in #24 I think, will try to drop by and check out the car/say hi if time allows.
I am in garage 20.
The other 2 Skylines that I am travelling with are in the garages either side of me.
I look forward to meeting you.
  • 5 months later...
It has been a while since the last update.
Bathurst was an experience and a half. It was much more fun and challenging than I gave it credit for. We did ok especially as this was more of a shakedown session for both the car and myself. I started at the back of the grid in 53rd place and finished the weekend in 27th with a PB of 2.35.8533. there was heaps more in across the top and I was running out of revs down Conrod.
The videos are here:
Race 1:- https://youtu.be/T4IP9x53Pcw
Race 2:- https://youtu.be/SalKIfMcw5Y
Race 3:- https://youtu.be/v63wPakgZjc
Then we came back to Perth and went to our first home round and blew the 3.7 ratio diff.
We swapped a spare 4.1 ratio diff and went to the next round. We were running out of revs down the back staright as well, oh well close ratio gear box life! i also had a TPS problem so we were either stalling on the start or spinning the wheels.
Qualifying:- https://youtu.be/9YeDqea2Vdo
Race 2:- https://youtu.be/nRHX_yOvpys
Race 3:- https://youtu.be/eNXmWk0tvFM
So now we are in the process of fitting a 3.5 ratio diff fro a 350Z into the subframe using the Gkteck offset bushes and standard 350Z drive shafts. The fit of these will be sorted in the next week or so. With the wider rear track we are hoping that the standard 350Z shafts fit nicely.
  • Like 3
On 6/29/2018 at 7:31 PM, Dale FZ1 said:
Watched Bathurst race 2 - fairly busy there!
 Car looked to run well, no obvious vices just running out of revs.  Going up Mountain Straight too?
What calculated road speed?
Cheers, race 2 was very busy. The first time behind the wheel for 3 years, the first time at Bathurst and the first time with this car configuration!
We only had 2 issues all weekend, we overfilled the dry sump tank so our fault which spewed some oil out the back of the car as the catch can over filled and later we found that the driveshaft bolts had loosened off.
Calculated top speed was 238 KM/H.
  • 2 months later...
The 350Z diff and driveshaft conversion was a success. As we have widened the rear track so we were also able to use stock standard 350Z driveshafts.
A couple of weeks ago we had our first race meet using the new diff setup (3.5 ratio) and it was successful. We have also now got the PDM to turn the gearbox and diff pumps on at 40deg to send the oil to the coolers.
The class we run in has a engine, wheel size wight matrix and at the moment the car is still 100kg too heavy. We will plan some weight saving as were going to rebuild the 25/30 which needs this extra weight but have decided to build a RB25.
The last race meet also had a little issue of a left rear leaky seal on the brake caliper which caused some issues in race 3.
I also need to work on my starts, they were beyond pathetic!
Videos of the last race meet:
Edited by racegtst
  • Like 1
  • 2 months later...
Been a bit busy and thought I better catch up.
September Race Meet
The tyres were stuffed to begin with so the little tweaks we made since the last race meet did not fully shine.
The day started with a lot of understeer especially in turn 8 but we tuned that out by the end of the day.
Qualifying was on and we qualified 4th with a 64.5.
Race 1 - Time to work on my starts again. Although still not that good they were way better than the last race meet.
I started 4th and finished 4th with a 64.29 lap.
Race 2 again the start was a bit better. I again started 4th and finished 4th with a best lap of 63.75. The fuel pick up hose fell on the pump in the tank which caused fuel pickup issues 2 laps from home. I had to limp home to finish.
Race 3, well the start was not the best but at least I did not stall it. Finished 3rd for the race and the day resulting in the attached trophy. The tyres by this stage were well worn but we still managed a best lap of a 63.9. As we could not fix the fuel pick up hose we tipped 45 litres more fuel into the tank than we needed thanks to Craig so we could have the pump submersed and hope that it would last to the end. All the extra weight made for a bit of hard work but I made it.
There were close battles all day.
Race 3 saw me having a bit of a dice with a Lotus from the Sports Sedans group and then a VF Commodore Sport Sedan. The Lotus let me through after a lap but I did have to battle the Commodore for a few laps. I gave him a touch in the middle of turn 1 and turn 2 and then later in the lap at turn 8 he was wide to the corner and then come across and clipped my front. Once I got passed I was were able to pull away and put at least 1.5 seconds a lap faster.
There was no major damage to the car which is a testament to the front bar and bar mounting support built by Andrew from Maddog Customs.
I had a few camera dramas yesterday so I only have Race 3.
We finished the day 3rd.
https://youtu.be/mFcpDHKm8Oc
  • Like 1
October Race Meet
After a few minor repairs and rebuilding the rear brakes we were ready for the next one.
What an awesome day. It felt like I was in the thick of the action all day.
I was able to beat my PB twice yesterday, once in qualifying and again the last race with a new PB of 62.8233 shaving half a second from my previous PB.
I had a camera issue in practice so only the rear camera worked. I will edit the videos over the coming week and put them up as there was nearly non-stop action all day.
The day started with qualifying in 2nd position on the grid. My starts for race 1 and 2 were way better than I have been doing with race 3 start not the best. I basically chased Craig in the WRX all the way to the finish line.
Race 2 was the reverse grid, I got a good start but other behind me got a better start and ducked to the inside and Andrew (Souvs) got a horrid start. The conditions were damp with light rain in the first few laps and it was a bit greasy. The opening laps involved chasing Paul and Andrew (Souvs) chasing me. Had my left hand mirror touch the Commodore mid corner which then let Andrew (Souvs) past. The Commodore holding me up a bit is where I lost the points for the day.
Race 3 I stuffed the start again. At the end of lap 1 I mowed the lawn down the front straight with a nice save I got back into it from last position. I thought I was stuffed as there 4 of us all within micro seconds of each other to chase down. Ole mate blocker was back but got around him and started to chase down Craig and Paul.
I finished race 3 in 2nd place but 3rd for the day on points behind Paul and Brad.
It was one of the most satisfying days with close hard racing all day and a new PB.
Race 1
Race 2
Race 3
Edited by racegtst
  • Like 4
  • 2 years later...
So I have been busy in the last couple of years and mostly updating the Facebook page.
I have got my flame suit on for the rest of this.
I have made a decision to change the engine in the car and throw away the turbo, fuel injection etc.
LS is shit so a Chevy SB2 that does have actual NASCAR history and driven by Dale Earnhardt Jnr has been put into the engine bay.
We have taken it out for a shake down yesterday and here is a bit of video. I was only running it about 7,200rpm instead of the 8,700rpm limit the engine has.
  • Like 3
  • 7 months later...
So after a diagnosis of prostate cancer and then the associated surgery and recovery, I was eventually allowed to get back behind the wheel. I took it to the local Collie circuit in WA for a bit more of a shakedown and after 7 laps broke the last standard item on the car. The driveshaft. This took 6 weeks to get sorted mostly due to getting parts from the US.
While I was in recovery mode the guys at M&W Ignition systems customised an ignition box to allow me to have flat shift on the sequential gearbox. It performed faultlessly on the first outing.
Late November I entered the car into the WA Time Attack event just to get some laps under the belt. It was entered in race trim, so Hankook Z221 mediums, 1,450kg overall weight. I was no expecting too much from the car or myself.
To finish 2nd outright was a proud moment. I was able to just get out there and bash in lap after lap, I got about 24 laps across 4 sessions in total and also improved my PB by 0.2 of a second.
Below is a couple of pics and the in car youtube video of the day.
  • Like 3
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
