Urgent Borrow: Trolley Jack + Jack Stands
Need to swap my exhaust for a stock zorst and I have already got an extension on my EPA notice. I have basically Sunday, Monday, Tuesday to get it swapped out and tested. I am free all those days.
Trouble is I don't yet have jack and stands. Have only come across dodgy looking ones and will keep looking for something suitable for purchasing. On that note I have been thinking of ratchet Kincrome stands if anyone has any comments on that and somewhere they sell the damn things! also looking for a decent trolley jack (low profile) possibly light as well.
Please reach out a bit for me and help me get this done :D
0400 346 056
[email protected]
49A Winfield Rd, Balwyn North
  • Replies 104
If you know someone with a Costco membership, get their low profile jack.
Grab some stands from Supercheap Auto. A Skyline isn't super heavy so pretty much any of them will do.
Yeah I wish I knew someone with COSTCO Membership I want that Arcan jack. I was going to buy it off Ebay for ~$200 but if I can't borrow a jack off someone i'll need to buy something before and Ebay jack will arrive.
Got it sorted, thanks guys. For anyone who reads this far. Still looking for Arcan Jack and kincrome ratchet stands strong enough to lift skyline if anyone comes across either in a shop or goes to Costco let me know!
Using the arcan jack today it was great in terms of lifting the car easily even with only half the handle on BUT We couldn't jack it very high. I think it's max height is too low. Anyone else find this? After jacking it up to full height we could only get one 'click' up the ratchet stands.
Car sounds weird now. So quiet to me but i'm not sure it's quiet enough for EPA test. It's a stock catback. Is that all I need to do to pass?
http://tinypic.com/m/fuwgp4/1
^ video ^
Edited by jukic.j
At first in the garage it seemed loud and so I took it for a drive and I was like :woot: is my engine even on?
It even felt more responsive... I was like is a smaller exhaust... better???!?! but then I gave it a bit of stick and no pull :verymad:
Naughty stock exhaust :domokun:
Has anyone noticed this sense of responsiveness with a smaller exhaust? I'm not sure if it's placebo but changing between gears seems quicker and smoother kinda.
I'd say it's loud cause it's in the garage man.
Bigger exhaust is only a benifit when you are running under boost. Just tootling round off boost a big exhaust actually robs some power but who cares about that ;)
Your rear wheels are like 10cm off the ground in one of those pics, is that the max height of the jack?
With my jack (full sized, not a little aluminium low profile) I have to remember to close my boot before I jack it up off the diff, so that my boot doesn't hit the roof of the garage :P
Edit: Mods, I'd also be removing your address out of the first post of this thread.
Yeah the wheels are a few cm off the ground in that picture. Clearance was good from the rear but I think the front was more difficult because of how far back you have to put the jack stands could only get one click on the ratchet stands and it was a little low. That being said you could just jack it up full height, stand it. Then roll the jack onto some sort of solid platform that it wont roll off and jack it up a bit more as someone said. That's something I could live with.
Don't worry about the address i'm in the process of moving out or I wouldn't have been so liberal about it :P
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
