  • 3 weeks later...
Been a bit quiet on the car front but first lot of parts have arrived.
Garrett GT2859R-9's (HKS GT-SS's)
HKS Actuators and all gaskets and parts needed for install
Splitfire Coilpacks. No use building a new engine and using the ancient OEM ones.
Nice new OEM Coilpack Harness
Nismo Engine & Transmission Mounts
Nismo 600cc Injectors (the other 4 are in a box in storage atm)
OK, first lot done. After speaking to Chris @Racepace with all the parts here (and the rest coming in the next delivery), I should get around 330rwkw on a safe tune. July can't come quick enough.
Just found this build and read through it, fantastic story mate, great to see some long-time owners (fewer and fewer these days)
Only on SAU are there quality R-chassis bulids such as your one, really enjoyed the pictorial updates all the best mate, should be in good hands with Racepace looking after your beast
Edited by squareznboxez
-9s are nice. Been thinking about getting some instead of the -5s as there response are better.
HKS actuators - need to be properly dialed in to ensure waste gate pressure is accurate on each turbo charger (the japanese instructions are not much help, but I have photos of this for mine).
Nismo injectors are really nice - just a shame they do not come in bigger sizes (600cc is there biggest)
Splitfire coils are really worth it - I remember putting on mine a while back (when the car was running) and instantly noticed more grunt and much better fuel economy.
Going to be keen to see more updates :thumbsup:
Thanks guys :)
I decided on the -9's as these turbos are as big as I'd want to go with 2.6L. This way I get decent power with response and a car that's capable of road, motorkhana, twisties and the track. (with minimal lag)
Racepace mentioned that they will be modifying the actuators and turbo's slightly. No other info as it's all their IP I guess.
I will be using 98RON so 600cc should be good for around 350rwkw with this setup but yeah would nice if Nismo made something larger.
The 330rwkw Racepace said the setup should do is at 20psi. Not really worried about how long a set of turbos will last as -9's are only $1200ea.
Some supporting mods are still to come that will be able to get the car tuned to the maximum of what these turbos can do and a whole lot more. Whatever Chris @Racepace recommended that makes more power on this setup and easier to tune has been ordered :)
  • 1 month later...
Finally. An update!
Haven't had much time to spend on the car lately but got the final lot of parts.
First off the lot are Nismo AFM's
Nismo Thermostat
Tomei Expreme Dump Pipes as recommended by Race Pace.
Shiny!
And finally.....
After considering an N1 with upgraded gears, Jun & Nitto Pumps,I decided to go with the Tomei Oil Pump
Annoyingly the parentals want to do some work on their garage so the car will have to be moved to another location till the rebuild, come July.
Thank god for mates with large sheds!
Ohhhhh I just love new performance parts.
Very nice.
Love the Tomei oil pump.
You do realize that you need an oversized sump to match the Tomie oil pump?
  • Like 1
Very nice.
New parts are fun eh?
The ultimate would need to be your Tomei engine though. That thing is all sorts of win!
Yes, getting a Racepace 8L (or might be 9L?) sump when it goes in for the rebuild :)
New parts are fun eh? Yes, they are.
The ultimate would need to be your Tomei engine though. That thing is all sorts of win! Thanks mate, she is pretty... however I think racepace engines are certainly top quality and have never heard anything bad about them :)
Good, that is peace of mind and reassurance IMHO.
Keep it up man.
Now.... Back to my scotch :P
Edited by Ants
Nice looking build, curious as to why Racepace recommended those Tomei dumps though, given they are smaller than the older generation Tomei dumps, and larger and cheaper options are available ie HPI
Was wondering this too
You will love the -9s :)
Might be reaching the higher end of the Nismo 600s, when I had them in my car on 330awkw with -9s injector duty cycle was reaching 87-91%
Now running ID1000s at 55% duty cycle and 350awkw -9s
Was wondering this tooYou will love the -9s :)Might be reaching the higher end of the Nismo 600s, when I had them in my car on 330awkw with -9s injector duty cycle was reaching 87-91%Now running ID1000s at 55% duty cycle and 350awkw -9s
350AWKW with -9s WOW!!!
Great result on that!
I can't remember the exact conversation however they did mention that Tomei are one of the bigger dump pipes out there. I also got them cheaper than the HPI ones.
Can't see them being a restriction with -9's.
350awkw with -9's! Awesome. Is this with 98RON?
I figure the Nismo's will do fine for a while and I will just get them swapped out for ID's if I decide to go down the E85 road (when I make it a strict weekender again)
Yep that's on 98, will go E85 once it's more available near me
Looking forward to seeing how this build comes along. Looks great in black and good to see you are getting it back on the road after 7 years.. Cheers, Cale
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
