Yeah I think I bought the DoLuck brace after I decided to take the full cage out. Was a bit depressed about losing it, as I really like it :)
Ah well, think of it as, you got the bottom part of the roll cage in the back of the car :)
The paintwork for whatever reason comes out pretty well in photos but it definitely needs work. The roof is probably the worst with some bad bog work near the front and minor leak near the windscreen, followed by the bonnet where the paint is pretty weathered. Rear guards also need to be lipped and the paint fixed up where the wheels have scrubbed. This will all be done after Racepace has finished their part.
Yeah, I was gonna say, it also being a black car, all the marks and what not are going to show up.
Yup, Jack moved the car :) Was good to catchup with him on the day.
Yeah, he moved my GTR to Racepace too!
Awesome fella!
The seats are actually off "Racepace" Chris's R33. (Snowman's old seats). I've given them a thorough clean with fabric cleaner since the photo and they've come out really well.
Came up great!
Hopefully go back this Saturday when Chris will take my old engine apart and show me what went wrong. (probably rings)
Interested in this part!
Take some pics too!
Will definitely take pics mate :)
Well the old Brembo front brake setup has moved on and found a new home. Was really interested in getting one of the D2 Kits as they seem like awesome value. Wanted the 8Pot 356mm kit however there has been a lot posted on these forums about them not fitting 17" wheels. Well I refuse to believe that ;)
Import Monster were kind enough to lend me a kit to test fit and see if they clear my 17" track TE37's.
Well you saw it here first -
They fit!!!
Tried to take a photo as best I could, they have more clearance than what it seems in the photos.
FYI - Wheels are 17x9". Unsure of offset but they're more aggressive than my 18x9.5+12 TE37's. Good quality forged race rims like LMGT4's etc should also clear.
Thank you Import Monster for lending me the kit to test fit & Racepace for bolting them on and testing!
8 Piston 356mm kit in red ordered :)
They fit!!!
You should have atleast 6mm clearance. Otherwise stones (on the road)/balled up rubber (On the track) will get stuck between the rim and the calliper and you will either gouge the rim (stones) or catch the robber on fire (err, rubber).
gonna say this on behalf of RBN1..............................................
'SHE'L BE RIGHT MATE'
Nice caliper / brake buddy.
That's good advice. I think there is about 5mm clearance currently. I'll measure up when the kit is fitted. I will be moving to 18" 's in time however just didn't want to ditch the 17"'s just yet.
Ants, there is a lot of "she'll be right" involved with this fitment haha
I gave Comp Friction a call about those AP's and they were around the $4.9k mark. Hugely awesome setup but I can't justify the cost for my build atm. Maybe later down the track if I become truly serious about tracking the car again.
They actually clear very nicely, I'd say as much as my R34 gtr wheels did.
Looks good mate!! I want black calipers now :)
  • Like 1
Nice and yeah, tight fit!
What's the setup you got at the rear?
2 Piston Brembos? Or just OEM Nissan ones?
OEM Nissan non Brembos with DBA 4000 rotors. Have bought a set of QFM A1RM's to go on there.Was thinking of possibly upgrading them as well but Chris swayed me, seeing as these cars are front heavy. Going to spend the $ elsewhere. May possibly get the calipers rebuilt depending on what the report is on their condition.
I see!
Yes, Chris also told me the same thing and to leave the rear calipers as they are.
Just get a nice set of rear rotors and brake pads and that should do you fine.
Dropped by Racepace this morning.
AND..
….....it's out!
Engine Progress - Bottom end has been assembled and head is on.
Tomei Oil Pump & N1 Water Pump
Lots of progress with rest of car too.
Fuel tank is back in with Nismo intank pump.
While the engine was out I've opted to have the HICAS removed. Racepace Lock Bar in place.
If you look closely you can see that the lines for HICAS have also been taken out. Weight saving of roughly 20kg for removing all the HICAS hardware. Power steering re-routed through cooler etc. Bilstein coilovers are also in.
Front and Rear Sway Bars also in.
RP don't see a problem with the current location of the Oil cooler so it will remain where it is.
BMC leaking from proportioning valve resulting in all the brake fluid slowly draining out over 7 years. Will be upgrading to BM57 (R33/34 GTR)
A few more things like the standard BOV's are also back. Roll cage will be removed shortly before the R34 GTR front seats are installed.
Motor is getting close to finish. Will need to wait till I get my cam covers back from Powder Coating.
Didn't have time to get the cam covers sent off for powder coating then wait to be sent back from Sydney so decided to paint them myself - Candy Apple Red
All paint removed with paint stripper and ready for primer.
Etch Primered and ready for paint
Silver Metallic base coat
First coat. RB26 Logo has been roughly masked up. Will peel off and use some thinner to get back to bare metal before clear coating.
Dunno why it looks a bit pink in this photo
All done with 3 coats of clear coat.
The colour has a nice subtle metallic look to it that doesn't come out in the photos. Unfortunately after this photo was taken I put them in some bubble wrap & after arriving at Racepace I realised that after 2 days the clear wasn't totally hard yet so they have some minor marks on them :/ Will get this fixed up after I get the car back. Shouldn't be too hard.
Old motor stripped of accessories. Importer told me it was a R33 N1 motor with N1 turbos - ends up it's a standard 05U block with standard turbos.
New motor coming along nicely. 9L sump and timing belt etc are on. Should be completely assembled this week and turn-key end of the week.
Will need to drop by to take pics of the final assembled engine before it goes in.
How many coats of the silver did you do? And how many coats of the red?
Always wondered how metallic finishes like this are done, looks the goods :)
Hi mate, thanks.
2 coats Silver. 4 coats red. The more coats of red, the deeper and darker the shade gets. Was a bit of an experiment on my part as I was always wanted to know how to do it as well. It's a very deep Candy Apple in real life without looking too showy.
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
