Happy Friday!
Just got this picture back from Craved Coatings of the finished product.
Cost around $308 including courier back to me. Should last for another 3 rebuilds at least ;)
Hopefully they arrive Mon/Tue. Gotta book the car in at Racepace now, which will make it a bit more than a year since the last motor died.
  • Like 4
Covers arrived back from Craved Coatings yesterday.
The below photo still doesn't do them justice. They're a deep metallic candy red. Pretty close to how I originally painted them.
Will take a better photo of them in better light once they're on the car.
  • Like 2
  • 6 months later...
Aaaaaand WE'RE BACK!
Admittedly, got the car back around a month ago but haven't had time to post anything about it.
Been pretty busy with the new home.........for the GTR. House with rear, drive through access and a nice big garage that will get some work done on it in the new year.
On a run-in tune @315rwkw 18psi. Gotta find time to get it between 5-800kms so I can take it back for a retune back to 335rwkw @20psi.
  • Like 5
Thoroughly enjoyed reading through all 25 pages, gave me some motivation for mine when it comes back from an engine rebuild.  Time to get saving.
Car looks awesome!
  • Like 1
It makes me happy you have this back....updates!
Update?
Just a bit dusty and unloved ATM. Haven't even done enough KM's for run-in of the new motor build yet. Gotta set some time targets, I think.
I know that a couple of people have said this, but I just read the whole thread start to finish in about 30 minutes glued to my screen! The way you have done your interior has seriously inspired me to buy lots of goodies off RHDJapan [emoji23] Recently got into my first GTR and this is my first post on the forums ?
  • Like 1
11 hours ago, Bennjamiin said:
I know that a couple of people have said this, but I just read the whole thread start to finish in about 30 minutes glued to my screen! The way you have done your interior has seriously inspired me to buy lots of goodies off RHDJapan emoji23.png Recently got into my first GTR and this is my first post on the forums ?
Welcome and congrats on the new R. The interior is a nice way to start off on one of these cars, if you just got yours. They look a bit bland these days and little bits and pieces really lift the overall look.
39 minutes ago, Anfanee said:
So how about those time targets? :banana:
Yeah I hear you. First service on the new motor will be in Jan so maybe a bit quiet till then unless I get motivated.
  • Like 1
  • 3 months later...
Updates!
First service on new motor and re-tune done. Back to where it was and it feels good.
16387163_10154458728317734_3744676137276
Recruited & trained new staff member to give it a wash.IMG_2554_zpswoy1pfw4.jpg
Also changed the wheel decals to current gen ones. (still in red)
Current state (yes i keep a document with all this info) :
337.4rwkw @20PSI 98RON.
Factory Pearl Metallic Black (732G)
Chassis Manufactured: September 1989
Engine
Racepace Forged Stage 1 Motor (N1 Block)
-Block/Head inspected, water and oil gallery plugs removed, hot tanked, crack and pressure tested.
-Block bored and honed (strainer plate), decked to correct compression height, crank tunnel line honed to RPM specs. Strengthen weak points in the block (similar to N1 block)
-Oil galleries modified, tap galleries, fit thread plugs, modify water galleries, new welsh plugs.
-Conrods resized, bushes, replaced and individually honed to suit piston pins
-New OEM R34 GTR Crankshaft, rotating assembly fully balanced
-Race Pace Custom Forged Piston and ring set (86.5mm)
-Improved combustion chamber shape
-Nissan N1 water pump
-OEM Nissan gasket kit
-Race Pace custom main and big end bearings.
-RPM Circuit Cylinder Head : Replace valve guides/stem seals, cut seats, face valves, match chambers, surface, re-shim valve clearances to RPM specs
-New OEM Cam belt, new tensioner and idler pulleys
-Fully blueprinted, block painted and precision assembly
Apexi PowerFC & Hand Controller
Garrett GT2859R-9 (HKS GT-SS)
HKS Adj. Wastegate Actuator Kit
Tomei Metal Exhaust Manifold Gasket Set
Standard Airbox with Blitz Filter
Nismo AFM’s
Nismo 600cc injectors
Nismo In-Tank Fuel Pump
HKS Intercooler Pipes
Tomei Oil Pump
Racepace 9L Extended Sump – Baffled With Trap Door
SFIDA Oil Cooler & Greddy Thermostat Controller Oil Sandwich block
Ron Davis 3 Layer Alloy Radiator
Nismo Thermostat
Splitfire Coilpacks & New Coilpack Harness
Racepace Adj. Cam Gears
Tomei Expreme Dump Pipes>
Racepace 3”>3.5” Front Pipe>Racepace Spec CAT>Racepace 3.5” Catback Exhaust.
Drivetrain, Suspension & Handling
·         Nismo Coppermix Twin Plate Competition Clutch Kit
·         Nismo Engine & Transmission mounts
·         Racepace Rebuilt & Modified Transfer case & ATESSA
·         Volk TE37 17x9” +0 Gloss Black – Falken RT615 : 255/40/17
·         Volk TE37 18x9.5 +12 Satin Black – Yokohama AD08R 265/35/18
·         Racepace Modified Tein Circuit Master RE Coilovers. 8KG/mm Front | 4KG/mm Rear Revalved & Modified to Racepace specs.
·         Whiteline Adjustable Front & Rear Swaybars & Links
·         Cusco Front Upper Control Arms
·         Whiteline Cradle Bushes
·         Whiteline Adjustable Castor Rod Bushes
·         Front Brakes: D2 8 Pot Calipers & 2 Piece Slotted 356mm Discs, Braided Brake Lines, D2 Street pads
·         Rear Brakes: DBA 4000 Slotted Discs, QFM A1RM Pads
·         Nismo Front (Brake Master Cylinder Brace built in) & Rear Strut Braces
·         Racepace Reinforced HICAS lock bar. All HICAS hardware removed/re-routed correctly by Racepace.
Body/Chassis
·         Nismo Optional Genuine 3 Piece Side Skirts
·         Nismo Optional Genuine Rear Pods
·         Nismo Front Bumper Ducts
·         Nismo Bonnet lip
·         Nismo Boot lip
·         Ganador Aero Mirrors (motorized)
·         GKTech Air Deflector Panel
·         OEM Brake Ducts
Interior
·         Nismo 320kph Speedo
·         Sparco 353 Suede Steering Wheel + Sparco Dual Horn Button Kit
·         R34 GTR Front Seats
·         Nismo Duracon Shift Knob
·         Superior Auto Creative Sunvisor Covers
·         Superior Auto Creative Carbon Shift & Handbrake Boot
·         Superior Auto Creative Carbon Armrest Cover
·         Leather Handbrake Handle Cover
·         Leather Door Trim & Passenger Door Handle Covers
·         Carbon Coated Interior Trim Pieces
·         Fire Extinguisher & CAMS Approved Machined Bracket
·         Carbing Multi Point Roll Cage
Electronics
·         HKS Boost Gauge
·         HKS Water Temp Gauge
·         N1 Headlights - Philips Vision Plus H4 Globes
·         JVC Head Unit & MB Quart Reference 6.5” Component Speakers
Other
·         Brand New OEM Headlight Switch
·         Brand New OEM Left & Centre Air Vents
·         Brand New OEM Door Handles
·         Brand New OEM Centre Console & Glovebox Mats
·         Brand New OEM Radiator Support Bushes
·         Brand New OEM Brake Line A-Clamps
  • Like 4
Did you ever get results from the fuel sample?
Any ideas on original engine failure? Action taken to prevent a repeat?
We knew it was fuel contamination and apparently the sample wouldn't tell us exactly what it was so we didn't end up getting one.
Guess i'll need to avoid small town servos. Will take gerry cans with me track day. Almost makes me want to go e85, if I'll be karting fuel around...
    • Impossible to remove the housing while turbo is installed on the manifold on the engine. So I have to do it anyways. I plugged it so there will not be any debris in there. Will vacuum aswell
    • would a r34 gtr hood line up with gt/gtt stock fenders? after latch, front bumper and hinges are swapped for gtr ones? or would the fenders be too low or high in relation to the hood surface? ( I believe seeing somewhere that gtr front fenders use some type of riser for the sides, but do not know how that relates to stock gt/gtt fenders.)
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
