hay guys im looking into buying a front mount intercooler for my r34 gtt.
i want to make close to 300kw at the wheels with using the factory plenum.
so im looking for the best cooling option eg shortest piping and not cutting holes.
any advice will be great
cheers
https://www.sau.com.au/forums/topic/419239-front-mount-intercoolers/
Plazmaman
/thread
Whoops you said no holes... Plazmaman does them too, but super Exxy.
I suggest Blitz kit, the Cooling Pro kits don't fit too well. Everyone has end up making brackets. On my friend's car, we opted to fitting it higher up which needed the foglight to be shaven.
Pay the difference and go the Blitz kit new.
Edited by johnnilicte
you need to cut holes with that one?
Also its eBay, some people have had no trouble and some people have. No eBay item seems to be the same even if you end up with using the same brand as someone else's that doesn't guarantee it will work the same as theirs.
Edited by raZ1911
Just get a cooling pro kit... done.
If you want no holes, no headache, great fitment, no fking about, no custom brackets, and shit that lines up get:
http://www.ebay.com.au/itm/BLITZ-SE-INTERCOOLER-KIT-SKYLINE-R32-R33-R34-HCR32-ECR33-ER34-RB20DET-RB25DET-/320842554529?pt=AU_Car_Parts_Accessories&hash=item4ab3b4dca1
Bolts up, the cooling pro one requires you to swear at it, make some custom shit and guess where everything goes because there's no manual.
Don't worry about pipework length. It's a myth. Let's look at a 3m length of 75mm pipe. Has volume 0.0044m3. That contains 5.5 grams of air at sea level and 40°C.
When your turbo is coming on boost it will be flowing at least 5000 grams/minute, which is 83 grams/sec. I'm pretty sure that you can see a pressure rise in that length of pipe inside 100ms and probably have full pressure no later than 200ms after the turbo is capable of supporting it. That's not lag. You can barely measure that sort of delay compared to how long it takes the turbo itself to actually spool up.
If you were able to shorten the pipework by a metre (or worse, it had to be 1m longer), the change in the pneumatic delay would be barely detectable against the mechanical lag.
So for easy fitment and no head f**ks buy a blitz kit.
Has any one do a thread on best flow and shorest piping ?
not really, but if you want shortest piping, etc..
  • GReddy Plenum
  • Custom piping
  • GT-R Core
But not really worth it, if you're just chasing under 300kW or so... Look at Hypergear, he is getting ~340+kW with standard plenum, and with a ling long FMIC
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • It's funny, as Ive seen plenty of people use them in cheap builds on YT. And they actually go okay, even though a lot of other maxspeedingrods stuff is terrible. Those turbos seem reliable enough, the only part being, a good quality turbo that is "identical" to it, will out perform it day in and day out. In both a lower boost threshold, and the ability to flow more air at the same boost pressure. As a cheap cheap replacement, not a terrible choice. For cheap and shouldn't blow in a day, not terrible (like other eBay/Temu turbos) for low cost and still decent performance, that's where the question comes in to play from the results I've seen. I'd actually find it hilarious to buy one, and strap it to a paddock basher or some other cheap as POS originally NA car, and send it to the moon!
    • The maxpeedingrods turbo is cheap and bolts on to stock parts. I think you just need a bigger silicone coupler for the intake. Its a cheap china turbo, but it's been running on mine for almost 3 years at 16-19 psi.
    • What do they look like right after you've tried to start it with everything connected? Also post photos of what they actually look like.
