1 hour ago, blah_blah said:
Small update
So a few things. Need to fix the rear camber so ordered hard race rear camber arms.
Also rear end bearings were gone so apparently it is easier to order a full HICAS delete kit:
Over the next month will also do a custom cooler piping job and custom airpod box.
May also do Sandown this month but not sure yet
Nice kit! Something to add to the shopping list perhaps is rear traction arms, they'll help counter bump steer in a lowered setup. Here's some more info from when I was looking into that: https://www.sau.com.au/forums/topic/448509-wheel-alignment-question-car-feeling-more-skittish/?do=findComment&comment=7570413
Re Sandown, I'm pretty keen on the Tempered session on Australia Day, might see you there :)
Thanks! Good to know re traction arms! trying to keep mods minimal and concentrate on seat time and a reliable car from here tho.
Looks like im out for Sandown, but if your in let me know and i might pop by
On 1/10/2017 at 10:13 AM, Leroy Peterson said:
You still got HICAS? That shit should be illegal.
Do broadford in March with me. (If I'm not flat out with work)
Hrmm i only just get back from Murica in March. My car wont really suit Broadford lol
  • Like 1
12 hours ago, blah_blah said:
... trying to keep mods minimal and concentrate on seat time and a reliable car from here tho. ...
Smart plan! I'm hoping to do the same :)
I have signed up for Sandown on the 26th, fingers crossed all of last year's issues are fully sorted. If you end up dropping by look for the silver 34 sedan with black wheels :)
On 1/9/2017 at 7:55 PM, blah_blah said:
Small update
15873030_1547821361898884_10733021024492
15873272_1547821401898880_30811198885244
15941199_1547821385232215_89167324168121
Awesome thread! Car looks brilliant.
Where did you order your hardrace parts from? I can't seem to find many sellers these days now
Will do!
Got my hardrace parts via Topstage :)
  • 4 months later...
ZZzzz not sure why my fb links are always broken.
Anyway just a small update doing a xenon projector retrofit atm.
Purchases some 2nd hand lights
18767390_1717804664900552_33819629814147
1st time baking in oven not great lol
18814235_1717804721567213_37423389454635
2nd time much better:
18835502_1717811568233195_61118913565889
Xennon kit has come through:
18920233_1717812311566454_36114802786519
18813545_1717804618233890_63794632662224
End product in a few weeks something like this without the red:
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
